samsung plasma problem.
  • gazza544
    • Nov 2013
    • 19
    HI I wonder if anybody could help with some advice please, I have a ps43f4500, when I plug the power in the screen flashes and then goes off, if I do get the tv on it stays one for around 30 seconds and goes off.
    When that happens the power led gives an intermittent blinking.
    Re: samsung plasma problem.
    When it stays on, is picture OK, without any lines or distortions?
    • gazza544
      • Nov 2013
      • 19
      No distortions at all, got as far as going in to the menu.
      VOltages all test present and correct they go to the levels they should and then start to decrease.
        OK, on the control board/logic board (in the middle of the TV usually above the stand) there is an LED. It should blink, when running about once every second. When it stops, does the blinking change? Does it stop blinking, or start blinking slowly?
        • gazza544
          • Nov 2013
          • 19
          Hi tom yes the blinking does change it slows down.
            Slow blinking indicates control board has detected a fault and has stopped the panel operation. Faults vary, Samsung don't indicate what triggers it (annoying to say the least.)
            It would be ideal if you have two multimeters to check Vscan/Ve and Vs/Va independently - see if one cuts out before the others for example.
            If you don't have two meters you can try heating/cooling things to see if you can get the problem to occur quicker, a hair dryer works well.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
            • bcstedt
              Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
              by bcstedt
              Just starting to crack into this one and wanted to get the ball rolling.
              At power on (plug in), power light on, relays click, repeat (sometimes)
              After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
              Removed Y-Main for inspection and testing
              This pic from:
              PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
              12-15-2023, 10:30 AM
