Sharp main board
  • Lum747
    • Jul 2014
    • Usa
    Sharp main board
    I have a sharp LC46D62U that is my personal set that I need a main board for, the board is # DUNTKD934FM01 V3 which is no longer available but I wonder if a V4 would work , so I wonder if anyone has a used V3 or v4 board they would like to sell ?
    I may have posted this before but I don't see it in the forum
    If anyone has on please pm me
    Thanks lum747
  • advant
    by advant
    02-03-2020, 12:25 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
