Where to buy STK Convergence Chip Set
  • tech2014
    • Aug 2014
    • 807
    I need 1 stk392-110 and 1 stk392-150
    They are for a hitachi 51F500 42" rear projection TV. It has convergence problem. I checked all the resistors and they are good, so need to replace ICs. Do I order the same part number listed above, or is there a new set that will work. Also, what are good reputable sellers. I live in Canada so if there is a place in Canada that sells them that would be great, but will order from US if I have too.
  • Lum747
    • Jul 2014
    • Usa
    Re: Where to buy STK Convergence Chip Set
    try bill's electronica in denver colo
    • zacheriaj
      • Jan 2014
      • 138
      the set has two different stk ICs? they should both be the same unless someone was in that set before. Pictures?
      You Can't Succeed Until You're Willing to Fail
      • R_J
        • Jun 2012
        • 9559
        Hitachi uses two different stk ic's in this model.
        This is from Hitachi website:
        STK-392-150 replaced by STK-394-160E (p/n CZ01341)
        Note: The STK392-110, STK392-120, STK392-150 Convergence Outputs ICs are no longer available.
        They have ALL been replaced by the STK394-160E (p/n CZ01341).
        Note: This replacement is not backward compatible. You can not put a STK392-110, STK392-120, STK392-150 in place of the STK394-160E, but you can use the STK394-160E in place of the STK392-110, STK392-120, STK392-150.
        Suggestion: Please replace the Outputs as a pair.
        I don't think too many places carry the stk394-160e
        KP components has the stk392-110 and the stk392-150
        http://richtechparts.com/default.html?s=y
        http://www.kpcomponents.ca/
