hitachi 50hk5600 problem with display
  • wolf1976
    • Oct 2023
    • 113
    • Ελλάδα
    hi
    i have the above tv and the display starts distorts the display at only in applications like you tube
    after and on the didital channels
    now without connect the antenna only the image of itsselfs tv i have the image i have in attach
    i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
    can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?
  • Diah
    • Feb 2013
    • 6498
    as usual 50 size Panel always rubbish and gate Transistor got bad
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4516
      • Italy - Milan
      Try press hard on the cpu then watch youtube if it improves..
      • tiki66
        • Jul 2016
        • 59
        • Croatia
        It's a display problem, those are Panda displays and they are rubbish, don't waste your time on it
        • wolf1976
          • Oct 2023
          • 113
          • Ελλάδα
          thanks all for your answers
          i agree for the display issue
          but i cant understand why at start the problem appears only on the application like you tube and when i watch digital channels alls were fine
          now it appears everywere from the start when i open the tv and without connect the anteenna
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4516
            • Italy - Milan
            Is it a task for Hercules?...
            PS: You can't trust for a diagnosis or another without tests..
            • wolf1976
              • Oct 2023
              • 113
              • Ελλάδα
              thanks for the advice i will test it
