SONY KDL-55HX800 - Need LED Backlight Strip
  • tsttz32
    • Aug 2014
    Trying to fix this KDL-55HX800. It had a small dark spot in the bottom right corner of the screen, and then the TV would shut itself down after about 20-30 seconds. If you would tap on that part of the screen, sometimes the spot would go away and the TV would work again...for a while. Until it came back. I have narrowed it down to a bad LED backlight strip. I swapped it with the left side LED strip on the bottom, and the dark spot moved to that side of the TV. I then tried resoldering each LED in that bad section, but that did not cure the issue. It must be a defective LED.
    I have searched high and low for this LED strip and I cannot find one anywhere. Does anybody know where I can find one?? Sony does not sell the part individually according to my local repair facility. You must buy the entire panel at $1500... no thanks.
    The part number on the strip is "sls55_5630_sony_240_1d_rev_100218"
    Any help would be appreciated.
  • tsttz32
    • Aug 2014
    Re: SONY KDL-55HX800 - Need LED Backlight Strip
    I was thinking even if somebody had a TV with a broken LCD that had a similar strip, I could maybe even rob some of the actual LED's out of and solder them onto my strip. I assume Sony uses similar LED's in many models. They are Samsung brand 5630 White LED's.
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • syedshueeb@gmail.com
      Black spot and vertical lines on Sony KD-55x9300C
      by syedshueeb@gmail.com
      Can experts please share their opinion on this issue where i have a black spot and vertical lines all over the screen.
      Is this fixable or needs a new panel?...
      03-31-2023, 01:29 AM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
