Samsung PN50B450B1DXZA Red Sparkles
  • Audioplus
    • Feb 2012
    • 157
    After repairing the Power issue with a new X Board, the set powered up, but has an amazing amount of Red Sparkles. I'm assuming that is a common issue? I updated the firmware which improved somewhat.
    Any comments on this issue?
  • Audioplus
    • Feb 2012
    • 157
    Re: Samsung PN50B450B1DXZA Red Sparkles
    did some research, guess when the Y Board is upgraded (replaced originally), the X board should be too, or vice versa. Anyone want to comment?
    Firmware and board adjustments are additional fixes. Sometimes they recommend replacing all the boards.
      What voltage is Vs currently set to? Try lowering it by 10V.
      • Audioplus
        • Feb 2012
        • 157
        Tom, is that on the X Board?
        Thank you!
        • Audioplus
          • Feb 2012
          • 157
          Received a comment from client that when the TV turns on it's somewhat OK, then the red sparkles get progressively worse to the point where you can't watch it. When the TV is turned off for awhile and turned on, it's OK then the whole scenario is recreated.
          Do you still think it's the Vs voltage?
          Please confirm if that is on the X board
            Vs is on the power supply.
            I'm not sure about the particular fault, but it's in a Samsung tech doc.
            • Audioplus
              • Feb 2012
              • 157
              I found the Vs test point and adjustment on the power supply. Should I also perform a factory reset or
              'Alignments should be performed whenever a panel is replaced or the SMPS, or Y
              Main board. Alignments such as Option Bytes and White balance should at least be
              checked for accuracy.'
              As mentioned in the Service Manual?
              These older plasma's are not very easy to trouble shoot.
              Thank you!
                No, just decrease Vs.
                These older plasmas are easier for troubleshooting, they don't shut everything down after only one fault...
                • Audioplus
                  • Feb 2012
                  • 157
                  The voltage at Vs and Va were identical to panel sticker. I decreased Vs from 209 down to 200. Still has sparkles, whether it's any better, I'm waiting to hear back from client?
                    Any chance of a photo of the fault?
                    • Kjell
                      Samsung Series 9 - BIOS issue
                      by Kjell
                      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                      08-01-2025, 09:15 AM
                      09-07-2024, 05:50 AM
                    • Nairolf
                      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                      by Nairolf
                      I have a Samsung DM32D display.
                      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                      Here’s what I have tried so far:
                      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                      From these tests, I suspect the problem might be on the mainboard. Could anyone...
                      08-24-2025, 03:47 AM
                    • vincentedel
                      Samsung SyncMaster 740n Phase Control Issue
                      by vincentedel
                      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                      04-22-2025, 12:33 AM
                    • Manucsl
                      QE65Q800TATXXC Samsung TV Issue
                      by Manucsl
                      Hello.
                      My TV is a QE65Q800TATXXC Samsung TV.
                      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                      Any ideas to check would be very appreciated 😊
                      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                      02-19-2025, 07:47 AM
