Panasonic TH-42PY80 10 blinks
  • Hombre
    • Jul 2013
    • 231
    • Croatia
    Hi guys
    10 blinks on this one.
    Caps on MC201 and MC301 already changed.
    15V present, so are all sub voltages on A board.
    Vsus is not coming at all after i press the power button. I tried with replacing MC201 and MC301 places as they are interchangable but problem stayed the same - 15V OK, no Vsus so i would rule those out as being problem?
    I isolated SC and SS board, but Vsus not coming up, not even for a second, not a single V.
    Thermal fuse on Vsus transformer isn't open, unfortunately
    I assume it is something on P board, Vsus section?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-42PY80 10 blinks
    this might be a long shot but try disconnecting A5,A6,A7 and turn TV on and see if you get white screen.
    • Hombre
      • Jul 2013
      • 231
      • Croatia
      Tried that, but no white screen, it simply doesn't power screen on, i assume it is because there is no Vsus present, but i am not 100% sure
      • tw2005
        • Oct 2011
        • 6458
        sounds definitely PSU issue, was going to suggest thremal fuse but you've tried that too.
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          Have you already checked the two mosfets driving the vsus for shorts? also I believe its fuse 201 for open?
          Liberating magic smoke one part at a time
            Do the fans on your set start spinning at all?
            • Hombre
              • Jul 2013
              • 231
              • Croatia
              They aren't shorted, and all fuses on P board are ok, not open
              No, not a single spin
              • Hombre
                • Jul 2013
                • 231
                • Croatia
                Can anyone confirm me that Vsus should arise when i press switch button, same as 15V come right up? Vda not present to (altough i read somwhere that it won't if Vsus is missing). Don't know if i should concentrate on something else or i'm on the right track
                • Hombre
                  • Jul 2013
                  • 231
                  • Croatia
                  OK, fixed it
                  Vsus was not coming on so I was checking every bit in that section and everything looked OK. Only thing that was missing is SUS_ON signal from MC701. Removed it from PSU and only thing that i could tell is poor soldering of IC on that module (CH47AUG-7A18) and maybe even some corrosion. Resoldered it, put it back on PSU and now Vsus came on. But still no Vda - and again everything was leading to that module (Vda_ON missing). Took it of again, resoldered IC, checked with magnifier, put it back on and voila - TV turned on
                  So another one PY (PZ) series with non common fault ended at my place, no easy fixes for me
                  • Andre Gilbert
                    by Andre Gilbert
                    11-20-2024, 08:52 PM
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • Buzztv
                    Panasonic TC-P42S60 Plasma,how to check Vsus
                    by Buzztv
                    This is my first post in attempting to keep my beloved 2013 Panasonic plasma tv going.
                    About 6 weeks ago the tv was turned on but then immediately shut off. There was no recent power surge or popping noise or any other symptom.
                    I checked all of the obvious things and decided to try a replacement power supply board (PSS in Panasonic lingo).
                    I would like to check the Vsus but this is one of the final models and at that point Panasonic did not indicate the Vsus and Vad voltages inside the chassis. It looks like they were discouraging people from making adjustments....
                    10-27-2019, 01:24 PM
                  • CrewmanRedShirt
                    Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                    by CrewmanRedShirt
                    Hello all,
                    As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                    07-13-2024, 11:02 AM
