Toshiba 32DT2U1 has 5v but no stby LED, wont power on
  • triplefour
    • May 2014
    • 1747
    Re: Toshiba 32DT2U1 has 5v but no stby LED, wont power on
    im stumped
    Don't fear the repair...
    • triplefour
      • May 2014
      • 1747
      would appreciate any suggestions! ...and i really cant find the service manual for this one
      • triplefour
        • May 2014
        • 1747
        any ideas before i junk this one??
        • triplefour
          • May 2014
          • 1747
          well i revisited this one today and i guess it just needed to rest because now its at least turning on when i press power. steady green light. and i was even able to hook up my n64 and hear some sound and when i shine a bright light at the screen i can see the graphics. i have 24v going to the inverter, but im guessing the inverter is just not doing its job.
          i dont even get a flash.
          there are 4 voltage regulators on the inverter, 2 of them read all zeros, the other 2 read all zeros except the middle pin/tab which reads 24v
          does that seem right?
          • triplefour
            • May 2014
            • 1747
            heres some pics of the inverter.
            i got 24v on the positive legs of both electrolytic capacitors
            i got 24v on the fuse
            i got 0v on the smd capacitors
            i got 0v on all the legs of the IC's except 15v on one of the legs of the 4 leg IC
            • triplefour
              • May 2014
              • 1747
              aaaaaaaand its back to being broken again. after working fine (except for backlight) for a couple hours, i turned it off to check the resistances on the transformers and when i turned it back on, the green light would come on for about 5 seconds then just turn off. non standby voltages would come up on the board and then die away with the green light. i decided to jump the power supply without the motherboard connected, and that worked. all voltages were present but still no backlight.
              when i tried to hook the motherboard back up though, now i dont get a green light..it just gets stuck in "on mode" as soon as i plug it in...voltages are there but the motherboard must be crashed cause i cant hear sound or change source or anything...so it seems like my psu is fine, my inverter has a problem, and my motherboard has an intermittent problem...
              oh yeah the resistances on the transformers were all infinite except for the 2 pins in the middle on the psu side of the board...those are 0 resistance. doesnt seem right to me. maybe theres a coating over the pins that i need to scratch away to get a better reading..
              • triplefour
                • May 2014
                • 1747
                after letting the tv sit for a few days, it was able to turn on again as before, and get sound and see graphics but still no backlight. since i found an inverter for only 12$ on ebay i decided to get it... but i guess i still have some kind of motherboard problem because after turning the tv off after running it for a while, its back to showing the green light for about 5 seconds and then turning off again...what could be happening here? some kind of eeprom that clears itself after being without power for long enough?
                i was able to turn the tv on and off again just fine a bunch of times. but after i let it run for about 30 minutes, i powered it off and was not able to get it to power back on again. just the green light for 5 seconds. then eventually not even the green light will come on...ill let it sit for another day or 2 and see what happens.
                • Capacitorial
                  Powersupply has all the voltages - Monitor still no power
                  by Capacitorial
                  Hello guys,
                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                  The weird thing is, that the Power LED is powered over the TCON board.
                  On The TCON...
                  12-28-2024, 02:12 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • ju123
                  Toshiba Satellite C50-A won't power down
                  by ju123
                  Hi guys,
                  So, I've been racking my brains on this one.
                  I have a Satellite C50-A which I'm repairing for a friend.
                  I recently replaced the main board due to failure.
                  Following this, absolutely everything works perfectly, except for the fact it won't power down.
                  Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                  01-07-2022, 04:40 PM
                  09-06-2024, 05:59 AM
