Panasonic th-50pz70b bottom screen fault
  • netdent
    • May 2011
    • 208
    Hi guys looking for some advice this huge plasma has a problem on the bottom half of the screen skin tones are most noticeable as having a blue negative look to them? hard to describe but as it's on 50% of the screen horizontal bottom I was thinking sustain board? would that make sense, I think the TV is probably too old to throw too much money at but would like to see what the experts on here thought? thanks for any help
    Ronnie
    sigpic
    Re: Panasonic th-50pz70b bottom screen fault
    Could you perhaps show us a picture of this fault?
    • netdent
      • May 2011
      • 208
      Hi Tom, the TV is at my daughters and I doubt it would show in a picture as the clarity is good it just has this blue hue on skin tones!
      Thanks for the reply
      sigpic
        First guess would be checking LVDS cable, it's an issue that does affect the PZ80s so maybe also PZ70. I would be surprised if it is a sustain (SC) or scan (SD) fault.
        • netdent
          • May 2011
          • 208
          Thanks again Tom, yes it's strange as the picture is great and sometimes you struggle to see the problem, most noticeable when faces are up close and take up the whole screen. would it mean changing the cable are clean and re seat?
          Cheers Ronnie
          sigpic
            Just remove, clean and reseat. Usually poking the cable with an insulated screwdriver will make the issue come and go.
            These panels do have great picture quality so are well worth saving... the black level might not be great but the overall PQ is excellent.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • kdaniel
              Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
              by kdaniel
              As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
              There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
              After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
              Left...
              11-16-2022, 09:23 AM
            • Rictech
              Panasonic SA-MAX770PU SMPSU board fault....
              by Rictech
              Hello everyone. 😀
              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
              There are no devices that have exploded or otherwise show signs...
              08-26-2024, 01:05 AM
