UN55MU6500FXZX dumps
  • Erickmen10@gmail.com
    • Jul 2025
    • Mexico
    Hello lotas
    I saw that you have a lot of knowledge to fix dumbs, and i am asking if could you help me to fix mine, it's for an UN55MU6500FXZX, the symptoms are no standby led and if unplug the mb the lights up.
    Thank you in advance
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4534
    • Italy - Milan
    WHY WHY WHY pollute other threads? Open your own one into respect for original poster.. !
    • lotas
      • Jan 2016
      • 4840
      • Russia
      Originally posted by Erickmen10@gmail.com
      Hello lotas
      Your dump is completely empty, read it correctly. The indicator (LED) of the standby mode will not be able to light up if you disconnect the cable from the power supply, since the LED is powered by the motherboard.
        • Jul 2025
        • Mexico
        Hi i created a new dumb and now isn't empty, also with another mb created a dumb, because presents the same failure symptoms.
        • lotas
          • Jan 2016
          • 4840
          • Russia
          Now it is read correctly, dump UN55MU6500f_Original was damaged, I fixed it, now write it down and after writing set and write status register 0x88, 0x42.
            • 22109
            Hello lotas
            Don`t hijack other thread topics in future please...
            Moved to a new thread....
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
            • Crystaleyes
              Samsung BN44-00259A standby question
              by Crystaleyes
              Hi all.
              I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
              SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
              Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
              The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
              08-11-2023, 05:15 AM
            • psssst
              Yamaha TSX 120 Standby Problem
              by psssst
              Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
              03-01-2024, 07:25 AM
            • reessi
              JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
              by reessi
              I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
              You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
              Years ago it had some bulging caps...
              04-26-2021, 11:42 AM
