Technika x23/50e
  • andyturbo
    • Aug 2014
    • 29
    • England
    Technika x23/50e
    Thought I would just share experience of recent repair. From standby when turning on green light for 3 seconds and back to standby. Found 7 x 25v 470 uF caps on PSU bad, c10 through to c16, all bad, highest reading 30 uF on meter. When replaced with decent caps running perfect. Got to say what cheap lot of rubbish inside. Mind you repair parts cost all of £1.12. Shame they did not spend a little more on parts in the first place.
    • 31283
    Re: Technika x23/50e
    Tesco - spend more on something?
    that's a joke right?
    did you know btw, Tesco stands for TESsa COhen - the company's owner.
    say's it all really!!!
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • Mark D
      Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
      by Mark D
      The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
      10-29-2024, 03:15 PM
    • Crystaleyes
      Samsung BN44-00259A standby question
      by Crystaleyes
      Hi all.
      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
      08-11-2023, 05:15 AM
    • psssst
      Yamaha TSX 120 Standby Problem
      by psssst
      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
      03-01-2024, 07:25 AM
