Samsung QN50Q6DTA
  • mrtek
    • Oct 2010
    • 65
    Samsung QN50Q6DTA
    Hi I just picked up a Samsung QN50Q6DTA. The issues was a 2 red flashes on the power button as the TV tried to turn on. Power supply OK. Backlight LED OK. If I remove the data cable from panel , sound is ON. I was able to identify the issue within one side of the panel. Used the tape fix and I placed the tape on 4 pins on one side of the flat cable. The TV ran great for 4 days and then the same problem appeared again...2 red flashes on the power button LED. Took the back panel off again and this time mode the tape on a different location and now the TV is running again. Am I missing something? Is this a normal behavior for a panel that is normally dying..or is the issue somewhere else?
    Anybody has the service manual for this TV?
    Thank you in advance for any feedback.
    Massimo
  • howardc64
    • Jun 2017
    • 653
    Massimo
    Probably need to investigate deeper on which signals pins are masked to gain further insight of the failure. Check service manual repository link (type "Samsung QN" into search box) if your main to t-con flex is similar to the QN55Q6DRAF service manual (pg 5-7 5-8 along with main board similaries on T-Con flex)
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4534
      • Italy - Milan
      Where are you from? A possible difference between before and after is the change of wheather / temperature, if you blocked now more faulty signals possibly the fake repair would last more, but do not expect much more, terminated one side, can be the turn of the other side
      • mrtek
        • Oct 2010
        • 65
        Hi Davi.P, I am originally from Alessandria but moved to the US in 1982
        Massimo
        • mrtek
          • Oct 2010
          • 65
          Thank you for the info.
          Yes the picture quality is not perfect but unnoticeable when viewing a TV show. More noticeable when using the TV as a PC monitor. Click image for larger version
ID:	3679553 Click image for larger version
          Unfortunately the Main to T-con is one cable only. The T-con is embedded into the main. I should have taken pictures before putting the cover back. Also I could not find a match for my TV type. The TV has been running all day with no failure. We will see what happens. Click image for larger version
          • lotas
            • Jan 2016
            • 4837
            • Russia
            Look at the buffer strips, are there such protective diode assemblies (TVS)?
            • mrtek
              • Oct 2010
              • 65
              I did not see any. I will look again.
              • mrtek
                • Oct 2010
                • 65
                did not have time to check. TV has been running for 2 days now with no problem.
                • lotas
                  • Jan 2016
                  • 4837
                  • Russia
                  Well, if the image with stripes suits you, then let it work that way.
                  • mrtek
                    • Oct 2010
                    • 65
                    it is very hard to see them..but right now I am waiting to see if the TV will fail like the first time.
                    • mrtek
                      • Oct 2010
                      • 65
                      Hi Lotas
                      I removed the TV back cover and I did not see any protective diodes on either side of the buffer strips. The image is from the end of the buffer strip where the tape solution was applied.
                      • mrtek
                        • Oct 2010
                        • 65
                        Lotas, after a second look , I did find some components that look like protection diodes. Click image for larger version
                        The circled components are the one that are connected to the pins that I have masked with kapton tape.
                        The test points in question ( LC2, LC1 and VGH) are not shorted to ground. Should I try to remove one of them tomorrow and see if the TV will turn on with only 2 pins covered with tape? I just do not want to make it worse BTW the marking on one of them seems to be S06 or SC8...under the microscope they look like diodes, very tiny..could not find a datasheet for them.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4534
                          • Italy - Milan
                          do not hope much that the diodes are failed, the fault is elsewhere..
                          • mrtek
                            • Oct 2010
                            • 65
                            Hi Lotas
                            Sorry this is the image of the wrong buffer board.
                            • mrtek
                              • Oct 2010
                              • 65
                              You are probably correct. One of the test points is VGH...I can't imagine that signal is dead , otherwise the whole TV would not work. I would have to check the signals with and without the tape applied on the flex cable.
                              • mrtek
                                • Oct 2010
                                • 65
                                New update.
                                I was ready to read the voltages / signals at the testpoints listed before. So I removed the end of the flex cable going to the faulty buffer board. Turned TV on and at the VGH test point I was reading 24.6V to -6.95V. It was fluctuating between these 2 voltages. Then I remembered that some Samsung have a feedback signal coming from the left and right buffer boards feeding into the T-CON circuit....it is a closed loop. Plugged the flex cable back with no tape applied expecting the TV to fail / not turning on. To my surprise the TV turned on and the screen showed the QLED logo and showed the home screen. Turned the tv off and back on...still no issue. now the TV is running perfectly and left it on waiting to fail.I now have no clue what is going on.
                                More updates later if anything happens..
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4534
                                  • Italy - Milan
                                  It can return to fault state or it was so for a question of moisture on cof tabs that is now gone.. let see how is going to do..
                                  • mrtek
                                    • Oct 2010
                                    • 65
                                    TV has been working every single day. Every day turn it on and at night I shut it off.
                                    • mrtek
                                      • Oct 2010
                                      • 65
                                      ...and still working...
                                      • mrtek
                                        • Oct 2010
                                        • 65
                                        as of today ...TV is still running...It is a big mystery.
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
