Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
  • Malva
    • Jun 2025
    • 6
    • Italy
    I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
    Mainboard model: EAX65684604
    PCB marking: EBT62954607
    SPI chip: Winbond W25X20CLNIG Problem description:
    Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
    After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
    • I bought another mainboard (same model: EAX65684604) from AliExpress.
      • That board works, but has no Smart functionality, no antenna/tuner support, and only one HDMI input working.
      • It seems to be a minimal or hotel firmware version.
    • I dumped the firmware from that board and flashed it into my original one using a CH341A programmer and SOIC8 clip.
    • After the flash the TV reports the same problems.
    • I have a backup of the original firmware.
    I'm looking for a clean, working dump (.bin) for this mainboard and TV model or for some advices.
    Feel free to share it directly or link it here. Thanks a lot in advance!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4326
    • Italy - Milan
    have you compared the original dump with the one from chinese mb with HxD?
    • lotas
      • Jan 2016
      • 4599
      • Russia
      The settings are stored in eeprom (AT24C256C), not in spi flash (W25X20).
      • Malva
        • Jun 2025
        • 6
        • Italy
        Yes, they have some differences but I tried anyway.
        For istance:
        • At byte 24: 0xBA (AliExpress) vs 0xB9 (LG original);
        • At byte 20482: 0xEC vs 0xD6;
        • At byte 20485: 0xA3 vs 0xAA;
        • At byte 20490: 0x85 vs 0x94;
        • and many others.
        As I didn't figure to find a stock SPI firmware I tried this way.
        • Malva
          • Jun 2025
          • 6
          • Italy
          Should I try to erase it and force the tv to regenerate it?
          Thank you
          • lotas
            • Jan 2016
            • 4599
            • Russia
            This worked in old models, in new smart models the region, Syrian numbers, mac address are registered.... Try doing IN STOP through the service remote (before any manipulations make a backup of the original chips).
            • lotas
              • Jan 2016
              • 4599
              • Russia
              To disable the LG Hotel Mode on your TV, you need to enter the service menu using the code 1105, and then disable the "Hotel Mode" function.
              Here are the detailed instructions:
              1. Enter the service menu:
              Press and hold the "Home" button on the remote control for more than 5 seconds.
              Enter the code 1105 using the number buttons on the remote.
              The "LG HOTEL MODE SETUP" menu should open.
              2. Disable Hotel Mode:
              In the "LG HOTEL MODE SETUP" menu, find the item responsible for hotel mode (usually it is the first item in the list).
              Use the up/down buttons on the remote to select this item.
              Press the "OK" or "Enter" button on the remote.
              Change the value to "Off" or "Disabled".​
              3. Exit the service menu:
              Press the "Back" button on the remote control.
              The TV should return to normal operation.
              The hotel mode is now disabled and you can use the TV as normal.​
              Additional information:
              If you are having trouble with code 1105, try other common codes such as 0000 or 0413.​
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4326
                • Italy - Milan
                when programming the flash, did you do the verify procedure?
                • Diah
                  • Feb 2013
                  • 6374
                  if this so easy to disable Hotel mode, then all Hotel user will have access to change what they like,, only using Service Remote and send IN_Stop command followed with 0413 TV go to STB,
                  • lotas
                    • Jan 2016
                    • 4599
                    • Russia
                    1105 - access code to LG Hotel Mode. You can change the code in the LG Hotel Mode menu. Accordingly, after changing the password, to enter LG Hotel Mode, you no longer need to enter 1105, but the same password that the hotel administrator set.
                    • Diah
                      • Feb 2013
                      • 6374
                      well lotas still IN_STOP the powerful command to put the set back to shipping state even if the administrator changed H.Mode PSW
                      • lotas
                        • Jan 2016
                        • 4599
                        • Russia
                        I already wrote about this (IN STOP) in post 6.
                        • Malva
                          • Jun 2025
                          • 6
                          • Italy
                          I am unable to find the EEPROM Chip on my mobo.
                          How can I access IN STOP without remote control?
                          Thank you
                          • Malva
                            • Jun 2025
                            • 6
                            • Italy
                            Yes, I also read again the chip and verified the dump
                            • lotas
                              • Jan 2016
                              • 4599
                              • Russia
                              EEPROM: AT24C256C (IC102)
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                do not expect much from a different model board, check also the 3,3v on the spi..
                                • lotas
                                  • Jan 2016
                                  • 4599
                                  • Russia
                                  If there were no 3.3v, the motherboard would not turn on at all.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4326
                                    • Italy - Milan
                                    both ir receiver and spi flash can be fed by 3,3v, so an overload of 3,3 v can turn off the flash and so the entire tv..
                                    • micsa84
                                      Mainboard problem Laptop Lenovo Ideapad 3 15ada05
                                      by micsa84
                                      Hello! I have a problem with a mainboard from a Lenovo Ideapad 3 15ada05.
                                      The problem is that the cooling fan is always on full speed, It doesn't recognize the battery and it is not charging it and the keyboard has only partial functionality, many of the keys don't work.
                                      I tried a new bios update but that didn't changed anything.
                                      What could be the problem with it?
                                      08-15-2023, 10:46 AM
                                    • AustinComputerDoctor
                                      Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
                                      by AustinComputerDoctor
                                      I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
                                      I see backlite is active,
                                      but I cannot get the screen to return back to menus , etc
                                      This is all after replacing the mainboard...
                                      any assistance is greatly appreciated.
                                      03-25-2024, 12:43 PM
                                    • theone111
                                      by theone111
                                      3. Problem: TV shuts down
                                      07-22-2024, 10:36 AM
                                    • dudochnicht
                                      Dell Inspiron 7520, LA-8241P mainboard problem, power on black screen
                                      by dudochnicht
                                      Hi, i have a Problem with my Dell Inspiron 7520 LA-8241P Mainboard.
                                      When i start it, all LED's turns on but the display is black.
                                      Shortly after starting I noticed a click on the mainboard but don't know where it came from.
                                      I have tested it with the i5 and after the click the laptop goes off but with the i7 the laptop stays on after the click .
                                      The Dell Inspiron 7520 supports the i7
                                      What I've already done:
                                      - start without RAM and it beeps 2 times
                                      - start without bios battery and it beeps 5 times
                                      - Press D on start,...
                                      10-24-2021, 06:43 AM
                                    • cheeky2
                                      Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                      by cheeky2
                                      I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                      Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                      The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                      Details:...
                                      08-17-2023, 04:34 AM
