Samsung QN95AA 65 one Connectbox
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    I have a Samsung TV 65" 2021 with One Connectbox SOC4002A BN64-04592A. The display simply turned off during operation, but the sound is still working!
    Is there a chematic
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    Turn the lights out if you can, turn the TV on and get the sound rolling. Take a flashlight to the screen very close and move it around to see if you can see a picture at all.
    Unless the screen lights up with no picture.. then you don't need to do it. Tell us what happens
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      Yes, I can see something.You can see movements etc. It's just not illuminated​
      • Strolch
        • Nov 2017
        • 237
        • Deutschland
        Can you measure the box? Or what would be best?​
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          What could be the best next step? Thx​
          • EazyBone
            • Jun 2023
            • 1347
            • United states
            Testing the backlights. Likely has nothing to do with the one connect box. I use an LED tester. Generally on a Samsung TV you disconnect the main board connector from the Power supply and it will turn the lights on .. but I can't remember if it works on the one connect box tvs.
            This is a mini led tv though? If the LEDs are bad then you are screwed. I believe these have a led driver boards? Best bet is take off the back and take a picture for us
            Edit, not sure testing the leds will help here with mini led tv. I've never had an opportunity to test ones LEDs.. I do know that your aren't going to be able to replace them though. Maybe you could jump a bad led or something..
            • Strolch
              • Nov 2017
              • 237
              • Deutschland
              Good Morning. Its a. 65" Neo QLED 4K QN95A (2021)
              • Strolch
                • Nov 2017
                • 237
                • Deutschland
                So I have now taken it off the wall and opened it on the floor.Which board is responsible for what? I was hoping I'd see a defective capacitor ;-)
                Ok the green is the LED Driver
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  The 10A Fuse is ok.
                  I just bought this LED driver for €40. There aren't many other options. https://www.ebay.de/itm/276874453944
                  • Strolch
                    • Nov 2017
                    • 237
                    • Deutschland
                    I have 61Volts at Fuse The TV is On! Is that OK?
                    • EazyBone
                      • Jun 2023
                      • 1347
                      • United states
                      I have no idea.. Samsung is always innovating their high end tvs and it makes them much harder to diagnose. Appears they did away with the PSU and are relying on the one connect box now.
                      guess you'll find out soon if it's the led driver lol
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        If only I had a Chematic or knew how many volts it should have!​
                        • EazyBone
                          • Jun 2023
                          • 1347
                          • United states
                          I don't think they release them anymore. Could be wrong though
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            I measured the four thick pins from the connector to the TV. Pin 1 has 61 volts, pin 2 has 16.7 volts, pin 3 has 0 volts, and pin 4 has 0 volts! Can anyone tell me if this is OK? I read something about 300 volts! Or can someone give me a schematic? Or has anyone already measured their One Connectbox? Thanks.​
                            • marekk
                              • Mar 2013
                              • 36
                              Unplug one out of eight white ribbon cables from LED driver to the screen and turn on the TV. If there is no difference, plug it back in and unplug another one.
                              If there is no difference, continue like that until you find backlight panel which is shorted, then TV will turn on with only portion of the screen black, rest of the screen will have backlight ok.
                                09-07-2024, 05:50 AM
                              • jchang
                                Samsung UN70NU6900F no picture and no sound
                                by jchang
                                Hi all
                                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                Symptom:
                                No picture no sound.
                                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                No sound at all.
                                What I tried:
                                1. I tried unplugging the left or right ribbon...
                                01-09-2023, 06:28 PM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                                09-06-2024, 11:40 PM
