Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
  • Ady2017
    • Dec 2017
    • 50
    I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that has failed. The background to this unit is that is sat in my dad's empty, cold and damp bungalow for about 3 years while he was in hospital so I was expecting some problems with it. I am desperate to get it working and save it as it holds a lot of sentimental value to me now.
    Is it possible to replace just the laser in the DVD drive or does the whole DVD module have to be replaced?
    Are there any other common problems with these that could cause this problem?
    Does anyone have a service manual for this unit?
    • 12183
    • U.S.
    First gently clean the lens with iso alcohol and a q-tip and try it if you haven't already.
    • lotas
      • Jan 2016
      • 4596
      • Russia
      The lens is wiped with distilled water, not alcohol.
        • 12183
        • U.S.
        Been using iso forever, always works with NO damage. So stifle it edith.
        • lotas
          • Jan 2016
          • 4596
          • Russia
          Alcohol can damage lenses, but distilled water is a safe and effective cleaning solution.
            • 12183
            • U.S.
            Very doubtful lotas. Isopropyl alcohol doesn't leave residues. Being a non-polar molecule it will NOT disolve any plastic parts (they are soluble only in polar solvents like acetone).
            As for "coatings", those are camera lenses, there's no need for antireflex coatings. Those coatings are there in cameras because you can take pictures against the source of light (sun). Is not the case inside an optical player, so they are not coated. Some may be coated, can tell by the color usually but iso has not been proven to damage them.
              • 12183
              • U.S.
              Never seen a problem with iso but if some are afraid and the lens isn't too filthy, you could use a tire pump, a vacuum that blows or the like. canned air is not recommended, it leaves residue, which is not what you want.
              • Ady2017
                • Dec 2017
                • 50
                I have tried cleaning the lens and the unit is still not working. Is it possible to buy a replacement lens or are there any other tests that can be done on it?
                • lotas
                  • Jan 2016
                  • 4596
                  • Russia
                  VXY2010
                  https://www.ebay.com/itm/116206939313
                    • 12183
                    • U.S.
                      • 12183
                      • U.S.
                      Looks like theyre discontinued or sum such, 50 ish there: https://www.aliexpress.us/w/wholesal...etail.search.0
                        • 12183
                        • U.S.
                        Might be able to get a whole unit to use for parts for yours, look there, apparently both those models use the same optic pickup: https://www.ebay.co.uk/p/2148630990
                        • Bazfletch3
                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                          by Bazfletch3
                          Hi all
                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                          From there I envisaged that the backlighting wasn't working, however...
                          01-08-2024, 10:18 PM
                        • kd9
                          Panasonic working hours bios location
                          by kd9
                          Hello, can someone tell me where the operating hours are located in the bios (string)? I have a client with a cf-20 who wants to reset them but I don't know where that information is found in the bios I we checked 2 versions of the bios but there are multiple large arrears that are changed . Thank you.
                          04-03-2025, 09:47 PM
                        • BadTelly
                          HDMI ports not working - Panasonic model number TX-P50XT50B 50"
                          by BadTelly
                          Suddenly all HDMI ports stopped working on a Panasonic 50" TV. This is model number TX-P50XT50B and has worked fine for years.
                          The TV turns on but no joy on either HDMI-1 or HDMI-2 and I've tested it using an input device and cable that works fine on another TV via HDMI.
                          Thank you in advance for any help/ advice.
                          Kind regards,
                          Bad Telly
                          11-26-2022, 11:26 AM
                        • MMH3
                          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                          by MMH3
                          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                          Never ever i experienced problems with that.
                          Now i have one 5050sff machine, where this jumper isnt working at all.
                          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                          The history of the machine is that i used it in my office...
                          03-23-2025, 09:28 PM
                        • DynaxSC
                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                          by DynaxSC
                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                          03-10-2025, 12:27 PM
