FIRMWARE SAMSUNG UE50KU6000K
This topic has been answered.
  • spantor
    • Jan 2020
    • 46
    • spain
    Mark: Samsung
    Model: ue50ku6000k
    Chassis (main board, components): 2n4102528
    LCD Screen/Panel (if exist): cy-gk050hhnv1h​
    Hello.
    I suspect the firmware is corrupted. Could anyone send me a working one?
    Or fix this one.
    It was read with SOFI SP8A.
  • Answer selected by spantor at 05-22-2025, 11:29 PM.
    lotas
    • Jan 2016
    • 4668
    • Russia
    Why do I conclude that my firmware doesn't work? In addition to this firmware, the motherboard also has three chips with firmware: EMMC KLM4G1FEPD-B031_IC1002, 24_512_IC1602, W25Q80V_IC1104.
    Post dump T-CON W25Q80V_IC1104, I'll take a look.
    • lotas
      • Jan 2016
      • 4668
      • Russia
      The motherboard (PCB) may have the number BN41-02528A, and not 2n4102528?
      Try this dump.​
      • spantor
        • Jan 2020
        • 46
        • spain
        Try this dump.
        Hello.
        Is model BN41-02528, code BN41-02528A
        You firmware not working. The symptoms are: it turns on and the logo appears for a second, then the TV turns off. After waiting a minute the backlight comes on, it turns on, but there's no picture. The stand by lights flicker when you press buttons.
        I still suspect the firmware.
        I hope my programmer is not a problem.​
        • lotas
          • Jan 2016
          • 4668
          • Russia
          • spantor
            • Jan 2020
            • 46
            • spain
            I understand. You may be right, and it's not that firmware that's faulty, but perhaps from another memory. My options are coming to an end because I don't have an EMMC programmer.. Thank you very much for your help.​
            • spantor
              • Jan 2020
              • 46
              • spain
              Would you be so kind as to check tcom firmware?​
              • lotas
                • Jan 2016
                • 4668
                • Russia
                It's in perfect order, try recording this dump 24Q40 again.
                • spantor
                  • Jan 2020
                  • 46
                  • spain
                  Unfortunately, it didn't work. Maybe it's the EMMC memory or just a defect in the motherboard. It's a shame.​
                    09-07-2024, 05:50 AM
                  • GeckoGreen
                    Samsung service bulletin: need firmware file for PN63C550 TV
                    by GeckoGreen
                    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                    Will you please help me get the [2D63]LOGIC.bin file for my TV?
                    05-17-2025, 02:47 PM
                  • sikocan
                    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                    by sikocan
                    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                    01-11-2024, 01:47 AM
                  • Mirenia
                    Samsung UEMU6199U - no Standby - bad Firmware?
                    by Mirenia
                    I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                    Voltages on the power supply board is okay. Backlight test is also okay.
                    I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                    So I think my TV has exactly this issue.
                    Can someone please fix the dump?
                    And how do you do that?
                    As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                    05-12-2025, 06:13 AM
                    09-06-2024, 11:40 PM
