Samsung tv dosent turn on (no signal/standby light out) after lightning hit the house
  • adaugaard
    • Jul 2014
    • 29
    • denmark
    Model nr.: UE32D5005
    inside of the frame is a number called:
    LTJ320HN01-J
    The lightning hit just outside our house and fried our Samsung TV and out toaster. Funny enough it did not do anything to our new LG 55".
    Anything I could do to try to fix it guys ?
    I tried to measure the fuse (marked as 1 in the picture) with my multimeter and it looks fine... or it gives resistance if that is the correct english word.
    I have ofcorse measures the power cord and where it goes into the tv... measuring 230v here in denmark.
    Any other logic steps to I should measure - be aware im fairly new in this so hope for your understanding that im a liiiiiitle sloooooowwww
    I tried to give each part numbers in the picture making it more easy for you to referer to a part.. and also helping me with understading what you talk about
    I also upload a picture of my multimeter since im a little unsure what it should be on when measuring other things than the fuze resistance.
    Big regards from Denmark
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Samsung tv dosent turn on (no signal/standby light out) after lightning hit the h
    what is the resistance reading off of the part numberd 3?,1?
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • adaugaard
      • Jul 2014
      • 29
      • denmark
      My multimeter is on "6 o'clock" for this meassure.. ohm 200 it says - asume that is the correct place yes
      On nr 1. I have cliped one of the legs from the curcit, for giving a clearer meassure (correct me if thats a wrong way do do it.
      Anyway nr 1. (the fuse) meassures around 00,9
      Nr 3 i still fully installed on the curcit - when i try to meassure it it gives no response at all... is that because i need to get it out of the curcit first ?
      • adaugaard
        • Jul 2014
        • 29
        • denmark
          That indicates the fuse is not blown and the surge protector device is also OK.
          CAREFULLY, with your meter on the 1000V DC range, check the voltage between "-" and "+" of the device marked 18. For 230V country, around 320V is expected.
          • adaugaard
            • Jul 2014
            • 29
            • denmark
            Should the power cord be on when doing this ? or is it because there is so much power "stored" in the unit im going to messure ?
            The messure I did before was with the power cord out - please correct me if that is wrong.
            Again thanx for understanding... im not very pro in this world
            • adaugaard
              • Jul 2014
              • 29
              • denmark
              I made the reading with out power cord plugged in.
              It meassures nothing when the multimeter is in the position like the picture i attached. DCV 1000.
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                take reading with power applied,your varistor and fuse are ok as per tested
                • adaugaard
                  • Jul 2014
                  • 29
                  • denmark
                  Same with or without power
                  on 1000v dc it says 001
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    can you post up a pic of the whole board,and also one of the underside (trace side)
                    • adaugaard
                      • Jul 2014
                      • 29
                      • denmark
                      Hey Multimeter.. sure can.. front and backside are attached here.
                      The frontside have full sets of numbers. Some of the pieces with 4 legs i have given a "a,b,c,d" maybe making it more easy to explain what to meassure on those units.
                      thanx
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        on the large filter capacitor (16 or 17) measure from negative lead with the stripe, to the fuse (1) meter set to ac highest setting,need to see if there is power getting to the board,.measure with power applied
                        also what resistance reading do you get on the part not marked, black disk with DSC next to the transformer marked (11)?,this is your thermistor ,should be around 30 ish ohms when cold.
                        and measure the voltage across the leads of caps 16 and 17,meter set to 1000VDC with power applied,carefull this may have high voltage on it 320+ DCV in an ideal world.
                        • adaugaard
                          • Jul 2014
                          • 29
                          • denmark
                          Hey Multimeter.
                          I attached a new picture with letters on each "leg" on each part now also... since it requires that i thing when explaining...
                          I made a big error at the start up (and one on the end of this comment).
                          1.Startup error
                          Pretty simple i know but the fuze leg was cut off when messuring the resistance... that way its logic there was no action up to nr 18. I put the leg back on the board and that helped.
                          I messured nr 18.. and there was 320 on leg A+D. On on the B+C there was 230.
                          Then multimeter slippede and while i was holding on the "c" messuring B... it sliped and catched A also... not so good - something flashed with a light - and sadly now the reading on A+D is around 6... and B+C is almost nothing.
                          I think I just burned nr 18.... jesus im destroing more than i fix hehe.
                          i also messured nr 16+17 and they were bot h around 320 i recall.... after i burned 18 these messures some very funny numbers... very low.
                          I hope maybe its because 18 is not sending power to them after the burn, and I have not also destroyed them also.
                          I messured nr 16 - leg A and nr 1 leg A - before i burned nr 18 its messured full power... after the burn it messures 0
                          Hmmm not sure how to get going with this now I made more trouble than before hehe.
                          Unsure what the part nr is for nr 18. If its the JP817... when searching og that on google and shopjimmy.com it finds nothing. Maybe i need to remove the cooling iron to get to the real part nr ?. Was just interested in seeing what the cost is for what I just destroyed
                            You probably popped the fuse...
                            • adaugaard
                              • Jul 2014
                              • 29
                              • denmark
                              Hehe one could hope so... is it possibel to check the fuse with it installed or do i need to cut of the leg again and meassure ?
                              • multimeter
                                • Jan 2011
                                • 739
                                • united kingdom
                                ooops !,well need to check the fuse again,and also the bridge rectifier to be safe
                                test the fuse solderd to the board no need to lift any legs at this stage,meter on resistance 200 ohm,power OFF reading
                                bridge rectifier (18) number pins left to right 1234
                                meter set to diode test power OFF
                                black probe to 1, red to 2 reading?
                                reverse probes 1 to 2 reading?
                                pins 2 and 3 should have no reading either way
                                pins 3 to 4, black to 3 red to 4 reading?
                                reverse probes, 3 to 4 reading?
                                • adaugaard
                                  • Jul 2014
                                  • 29
                                  • denmark
                                  Diode test... hmm not sure where that is on my multimeter.
                                  Can you see my multimeter in the start of the post?
                                    One click right of 200 ohms, looks vaguely like this: ->|-
                                    • adaugaard
                                      • Jul 2014
                                      • 29
                                      • denmark
                                      test the fuse solderd to the board no need to lift any legs at this stage,meter on resistance 200 ohm,power OFF reading: 0 - no response - asume this means it killed the fuse right ?
                                      black probe to 1, red to 2 reading? 0
                                      reverse probes 1 to 2 reading? 483
                                      pins 2 and 3 should have no reading either way: correct its 0
                                      pins 3 to 4, black to 3 red to 4 reading? 0
                                      reverse probes, 3 to 4 reading? 490
                                      • multimeter
                                        • Jan 2011
                                        • 739
                                        • united kingdom
                                        ok,your bridge is fine,on your meter in resistance setting probes apart what does the meter say?, "0" "0.00" or "1" ?
                                        0.00 would indicate fuse ok ,a 1 would indicate fuse open
                                          09-07-2024, 05:50 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                          09-06-2024, 11:40 PM
