Qn65q800taa won't start
This topic has been answered.
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Did some of the usual troubleshooting.
    Unplug main board connector and back lights come on and stay on and PSU supplies all correct voltages on the legend.
    When you just plug in the TV the PSU relay clicks on and off immediately and then continues to click on and off every 20 seconds or so. The red light on the front flashes once and then 5 to 8 seconds later flashes once again and continues the cycle with the relay.
    I've disconnected each you ribbon cable one at a time and every single T-Con cable one at a time to see if there's any change. No change as long as the main board is connected. I have also disconnected all ribbons leaving the main board to the panel and the TV performs exactly the same way.
    When it is clicking on the PSU the back lights don't do anything and the TV does nothing except for the red light blinking.
    Anyone got a clue about this. It seems that the motherboard is a common failure on this TV.
  • Answer selected by EazyBone at 05-03-2025, 08:28 AM.
    lotas
    • Jan 2016
    • 4832
    • Russia
    A common problem with this motherboard is processor failure, a high-quality processor reballing is needed.​
    • Diah
      • Feb 2013
      • 6537
      where are the 2 cable at the t-con side going which under the 2 speaker ?
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        They also go to the buffer boards.
        • Diah
          • Feb 2013
          • 6537
          so they are non T-CON data just related to Dimming.
          disconnect only both left and right... and disconnect Mainboards to T-CON dimming socket ... let see what you will have... the rest should remain in place
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Iike this correct? If yes then exactly same. Relay clicks and it still blinks the same
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              So far if I disconnect only the main board from PSU does anything different happen. I've tried a combination of disconnecting everything I possibly could without any change to the symptoms
              • Diah
                • Feb 2013
                • 6537
                you have dimming , when you disconnect MB from PSU you have BL. but here the MB monitor to shutdown BL are out of the circuit. i would first suggest to take the screen out to see when at this test you did all Zones BL working as now you just see there are BL
                • EazyBone
                  • Jun 2023
                  • 1362
                  • United states
                  One thing I didn't try (and did now) was keep everything connected and unplug the ribbon from top of main to the led driver.
                  After doing this, the BLs turn on, stay on and then when the relay clicks about 20 seconds, the voltage drops as normal, they shut off and it repeats process. This is different from the usual Samsung rebooting.. at least how it appears anyway. Does this change any opinion?
                  As for your test Diah do I need to take the screen off or can I just use my tester on the lights and look for voltages?
                  • Diah
                    • Feb 2013
                    • 6537
                    take the screen off are the best. its just one time , if every things fine then we can dive deep at parts
                    • Diah
                      • Feb 2013
                      • 6537
                      at this point of test do it again but disconnect the Panel complete from T-CON
                      • lotas
                        • Jan 2016
                        • 4832
                        • Russia
                        • EazyBone
                          • Jun 2023
                          • 1362
                          • United states
                          Noted, I've taken many screens off I guess I can.
                          lotas do you have any source of this data also? Or just experience?
                          I see eBay has a repair service for $300 which is just stupid, but if no main boards exist I would be inclined to think it's likely going this way also.
                          • lotas
                            • Jan 2016
                            • 4832
                            • Russia
                            Here is one of the topics, and the same is on Russian forums, that there is a defect in the soldering of the processor....
                            https://www.eevblog.com/forum/repair...nboard-repair/
                            • Diah
                              • Feb 2013
                              • 6537
                              when you did the test... did the audio Optic port lit red at time the BL turn on ??
                              • EazyBone
                                • Jun 2023
                                • 1362
                                • United states
                                Optical remains red always, it's always on yes, as long as main board is connected.
                                And thx lotas I'll also read that
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  Started to read that, and that's exactly how my problem is going. At a kids museum but I'll read the rest when home. I don't know other tv repair forums so that's awesome too
                                  • EazyBone
                                    • Jun 2023
                                    • 1362
                                    • United states
                                    Pulled screen just because I haven't seen under a 8k screen before. Lights look good. All zones light up
                                    I see why a "good" reflow station is needed for main board. The entire bottom has a giant heat shield on the bottom of it. Although the spot where the IC is open almost every else has it. I'll send a pic with it soon.
                                    • Diah
                                      • Feb 2013
                                      • 6537
                                      "good" reflow station are nothing, another methode also work perfect, only stencil are the Professional
                                      at the end all Roads drive you to Rom
Name:	Soc Refllow.jpg
                                      • EazyBone
                                        • Jun 2023
                                        • 1362
                                        • United states
                                        Well I ended up picking up a ir6500 for $100 which I felt was damn good price. So I'm testing with boards currently but seems like it's working pretty good .
                                        • EazyBone
                                          • Jun 2023
                                          • 1362
                                          • United states
                                          So was able to reflow the chip and now the same pattern doesn't happen.
                                          Now the tv turns on with backlight, the red light flashes like it's being held down and there is now no picture. Yay 😐
                                          Only did the chip mentioned. I do not have those shorts as mentioned either
                                          • TrisHCl
                                            LED TV Boot loop - UE40F6500SB
                                            by TrisHCl
                                            First post...
                                            I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                                            Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                                            I disconnected the main board from the power...
                                            02-06-2025, 08:42 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • cmlewis89
                                            LG 47LB5DF blown power supply board
                                            by cmlewis89
                                            Hi folks,
                                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                            09-03-2024, 07:50 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • mrautom8
                                            Samsung TV UN75H6350AFXZC main board schematics?
                                            by mrautom8
                                            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                            While relay is on, all voltage rails are present and steady (scoped) on main board.
                                            I love a good logic puzzle but getting lost without any schematics.
                                            No shorts on ANY capacitor main board.
                                            Thermal camera shows 3.3V inductor getting warm instantly but...
                                            10-19-2025, 06:32 PM
