Sony kdl-37s5500
  • betton
    • May 2010
    • 13
    Sony kdl-37s5500
    Hi I wonder if anyone can help me
    I have a Sony kdl-375500 witch has a screen problem
    It is very pale white as if it,s misty, could this be the T-con board
    any help would be appreciated
    Thanks in advance Graham
  • betton
    • May 2010
    • 13
    Re: Sony kdl-37s5500
    Hi does anybody know whats causing this problem
    thanks Graham
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Seems like the gamma problem with the failed AS15 chip on the Tcon board.
      • betton
        • May 2010
        • 13
        Thank you
          Post a picture of the T-con board and we can help you test it if you have a multimeter of some kind.
          I had a KDL-37U4000 with a similar issue, I believe it to be of a similar series. And it was an AS15 gamma IC fault.
          • betton
            • May 2010
            • 13
            Hi, picture of T-con board
            regards Graham
              Top right corner of board.
              https://www.badcaps.net/forum/attach...6&d=1404632754
              There are points marked VG1,VG2,VG3...VG22. (Some may be missing.)
              With your multimeter on the 20V range (or autoranging DC volts if available) test the voltage on each point. Red probe on the test pad, black on the chassis. Report each reading in order.
              • jonscadden
                • Aug 2014
                • 6
                • england
                Hi have the same problem, customer took it to Authorised Sony service and they say it's the LCD and quote about $600 for repair. I am an apprentice trained TV eng and though a bit rusty on LCD I am no t stupid What do you think? It did Once flash up ok.
                  You can do the same test as detailed above and post your results. If you have decent surface mount soldering skills, repair will be easy and cost only a few £.
                  • jonscadden
                    • Aug 2014
                    • 6
                    • england
                    Does it matter about the rest of the letters and numbers after as15 on the as15 chip?
                      No, you can use AS15-F to replace AS15-U for example.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Yes it does. AS-15G must be replaced with AS-15G same with the F suffix and any others.....
                        TELEFIX
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Really Tom...?
                          I was lead to believe that you had to use the same suffix....
                          TELEFIX
                            From what I've heard, no T-con relies on the difference
                            (AS15-U = Unleaded, but not RoHS compliant due to bromide content; AS15-F = Lead Free RoHS, AS15-G = Lead Free RoHS with Thermal Pad.)
                            • jonscadden
                              • Aug 2014
                              • 6
                              • england
                              Thanks for that, both of you, so it really relies on how well the solder will take and how good you are, ia m pretty good and have soldered much bigger devices (apprentice trained City and Guilds Electronics Engineer).
                              Did any body have any thoughts about my reply, above, about the KDL 37s5500.
                              Sony authorised say its is the LCD and will cost £400. Don,t believe them as raster is present and vague, washed out image is there. Set brought to me after Sony. All PSU voltages correct
                                I think it is a gamma reference problem. However if you want to be sure, you can check the VGAMA, if they are poor it will prove the problem.
                                • jonscadden
                                  • Aug 2014
                                  • 6
                                  • england
                                  can you explain that to me. although qualified it was a long time ago and my lcd knowledge could be better.
                                    See post 7
                                    https://www.badcaps.net/forum/showpo...21&postcount=7
                                    • ijchan223
                                      • Jun 2014
                                      • 13
                                      • usa
                                      I have quite a few sony tv with the same issue. Where is a good place to get the AS-15G chips, Are the chips from china worth a crap ?
                                      • jonscadden
                                        • Aug 2014
                                        • 6
                                        • england
                                        Type the number into Ebay available for pounds.
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO Tap 11 Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Tap 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tap 11 boardview and Tap 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
