Samsung LN40A530 tries to power, recycles continuously
  • Audioplus
    • Feb 2012
    • 157
    Won't power on or off, keeps trying to turn on, LED blinks 3 times and you hear the audio attempting to initiate. Replaced Power Board, same issue, attempted to freeze T-Con, same problem. A tech friend commented to disconnect power cable at main board to determine if main board is the issue. No response when I remove main ribbon cable at main board.
    Any ideas?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LN40A530 tries to power, recycles continuously
    It won't power on without the mainboard.
    You need to jump the powersupply on.
    • Audioplus
      • Feb 2012
      • 157
      Hamie, do you think it's the main board? I get a fiber optic digital flash.
      But an associate tech is adamant that it's the power board
      • Audioplus
        • Feb 2012
        • 157
        I also disconnected power to the inverter, same thing, attempts to recycle.
          Try with t-con cable unplugged, but main board and power board properly connected.
          • Hamie
            • Apr 2014
            • 1383
            Need to eliminate the powersupply first.
            Jump pins 1-3
            Pin1 is the one with the arrow pin 3 is the one directly next to it.
            Unplug the mainboard and jump it like this. (But between pins 1 and 3)
            If it continues to relay click on and off then you have a faulty powersupply.
              What is the full model number of this TV? There are more than one version of this TV.
              http://www.shopjimmy.com/catalogsear...msung+LN40A530
              Which one is your power supply? BN-XXXXX???
              • Audioplus
                • Feb 2012
                • 157
                With disconnected T-Con, the TV powers up, displays a gray with no graphics
                • Audioplus
                  • Feb 2012
                  • 157
                  Samsung LN40A530P1FXZA
                    "With disconnected T-Con, the TV powers up, displays a gray with no graphics" that is normal to have grey screen without T-CON. So it will stay on without cycling on and off? If that is the case, you can connect the T-CON back and then disconnect the ribbon cables between the T-CON and the LCD panel to see if it will also stay on.
                    • Audioplus
                      • Feb 2012
                      • 157
                      No, with T-Con disconnected from panel, it goes back in to an attempt of power recycle mode.
                        On these Samsung LCD TVs you do not need to do this jumper - they will turn on automatically with the connector unplugged, backlight and all.
                        It would appear the T-con board is defective in this case.
                        • Audioplus
                          • Feb 2012
                          • 157
                          As always, thanks Tom, that will be the next part I try. Rather invest in a T-Con than a main board. I already have an extra power board.
                          • Audioplus
                            • Feb 2012
                            • 157
                            FYI, I will post if successful, it will be about a week, we have a holiday (4th of July). I guess you all are aware of that on your side of the Pond?
                            Thanks to all of you!
                            Dan C
                              Good, just want to verify that it is not the shorted circuit (shorted TFT drivers, caps, etc.) in the panel that is causing the problem. So T-CON is suspected.
                              • Audioplus
                                • Feb 2012
                                • 157
                                I hope so Bud!
                                • Audioplus
                                  • Feb 2012
                                  • 157
                                  T-Con, Tom you're the best! You should actually charge for your services or consulting. I found an untested T-Con for $9 on Ebay and $3 shipping from Delaware to Idaho in 2 days for $3
                                  Total $12
                                  Anyone need a power supply
                                  Regards and happy 4th!
                                  Dan C
                                    09-07-2024, 05:50 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
                                    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 06:20 PM
