Murphy tv19uk10d
  • sordids999
    • May 2013
    • 2161
    Murphy tv19uk10d
    hi guys ive got this latest tv the left speaker has a annoying loud buzzing sound any ideas whats causing this ?
    thanks
    Re: Murphy tv19uk10d
    The right speaker is / is not affected?
    Sound good from left but with buzzing - or no sound only buzzing?
    All inputs affected or only certain inputs?
    • sordids999
      • May 2013
      • 2161
      hi tom
      the right speaker is fine ive just found a spare pair of speakers but its the same problem with those installed ive tried the tv with hdmi connected the sound in the right is fine,it also buzzes with nothing connected on the left side
        So with only left connected you can ONLY hear buzzing, or you can hear audio + buzzing?
        • sordids999
          • May 2013
          • 2161
          audio and buzzing but its slightly distorted tom
            Can you get the part # of that chip near where the connectors for the speakers are... NXP something or other.
            • sordids999
              • May 2013
              • 2161
              Nxp tda1517p
              g57265
              yng08403
                Trying to think of an easy way to test it... You could try hooking up a pair of sensitive headphones (600 ohms or greater) to pin 9 or pin 1 to check the audio signals going into the amplifier. Otherwise, you will need an oscilloscope to test it.
                • sordids999
                  • May 2013
                  • 2161
                  ok thanks tom
                    • 31286
                    could be a bad dc blocking cap,
                    but that usually makes these types of amp get VERY hot.
                    maybe instead of headfones,
                    you link the left & right inputs on the chip.
                    if you get noise on both channels it's before the amp.
                    • sordids999
                      • May 2013
                      • 2161
                      UPDATE :
                      just a update incase anyone else has this fault it was the power supply at fault luckily had a spare unit which i changed tv fired up no problem with no buzzing,turned out it was the main cap bulged which i missed
                        The 400V one?
                        • sordids999
                          • May 2013
                          • 2161
                          yes tom
                            I'm surprised that didn't cause other issues; only a matter of time, at least.
                            • valente222
                              LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
                              by valente222
                              Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
                              11-18-2024, 03:21 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
