tv combo trevi ltv 2122 hdtv spento
  • mariorocco
    • Jun 2015
    • 8
    • Italia
    Main : T.EME380.61
    Pannello:CX215LEDM​
    Cerco Dump flash
  • lotas
    • Jan 2016
    • 4567
    • Russia
    DSM LED2200FHD T.EME380.61 CX215LEDM 25Q64
    • mariorocco
      • Jun 2015
      • 8
      • Italia
      Grazie.
        • 20708
        Originally posted by mariorocco
        Grazie.
        Post in english please !!!
        • mariorocco
          • Jun 2015
          • 8
          • Italia
          All right.
          Mario.
          • KYBOSH
            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
            by KYBOSH
            Saved this beast from the landfill this weekend.
            Manfactured July 2013 in Mexico.
            I love working on plasma TVs.
            Its been a while but I was lucky enough to find 2 this week.
            The TV powers on and stays on but no picture. Havent checked for sound yet.
            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
            Will start troubleshooting tonight.
            10-17-2024, 01:17 PM
          • dave8647
            How hot is too hot for an HDTV power supply thermistor
            by dave8647
            My question is a general one, but applies in this case to a Samsung BN44-00342B power supply with a thermistor labeled as NT801S. How hot is too hot?
            The TV is working fine and the power consumption is normal (~200-250W). But the thermistor is super hot, measuring around 200F (~100c) or more depending on brightness. The circuit board under it is slightly darkened. But I can't believe this is normal and am wondering if I should replace the thermistor.
            05-13-2021, 01:58 PM
          • riccoricco
            sharp lc40le820e, il televisore rimane spento, non accende
            by riccoricco
            Good evening. The TV, as per the title, was completely turned off at a voltage test on the power supply board marked "DPS-126CP" known that the 13 volt output of the "Q7911" appears but not on the "C7962" the 5 volt and present a light hissing from the card in question, I try to close contact 3 and 4 of the optocoupler location "pc7702" and I am pleased to note that the screen lights up even if it is white and the 12 volt that feeds the "T-CON" also appears in the part where the sensor controls appear remains off after a few seconds the TV switches...
            03-21-2021, 12:49 PM
          • aeneas
            Strange behavior when turning on my Samsung LN40A550P3F 40" HDTV
            by aeneas
            Based on my limited past experience along with other reports this is a common problem with Samsung (and possibly other brands of) TVs. When turning the TV ON, it takes a long time and seems to cycle through various peculiar states before it will operate properly. I've also had this same problem with a slightly older Samsung 40" HDTV. In the prior case, it was pretty easily repaired by replacing blown out capacitors on, what I think, is called the Power Supply Board. In that prior case the bad capacitors were pretty easy to identify by swelling that was conspicuous on the top of cylindrical...
            11-18-2019, 03:21 PM
            MediaTek MT8222 LCD TV Schematic
            The MediaTek MT8222 is an ultra highly integrated single chip for flat panel TV
            supporting multimedia video/audio input and output format up to full HDTV. It includes
            advanced 3D comb filter TV decoder to retrieve the best image from popular composite
            signals and embedded HDTV/VGA decoders for the high bandwidth input signals perfectly
            reproducing.The new 4th generation advanced motion adaptive and motion estimation
            de-interlacer converts accordingly the interlace video into progressive one with overlay of a
            2D graphic...
            10-31-2024, 02:18 PM
