sharp lc40le820e, il televisore rimane spento, non accende
  • riccoricco
    • Mar 2021
    • italia
    Good evening. The TV, as per the title, was completely turned off at a voltage test on the power supply board marked "DPS-126CP" known that the 13 volt output of the "Q7911" appears but not on the "C7962" the 5 volt and present a light hissing from the card in question, I try to close contact 3 and 4 of the optocoupler location "pc7702" and I am pleased to note that the screen lights up even if it is white and the 12 volt that feeds the "T-CON" also appears in the part where the sensor controls appear remains off after a few seconds the TV switches off. I decide to replace the optocoupler mentioned together with the other three and I am pleased to note that now the sensor controls part lights up even if no flashing appears, the TV behaves as before with the exception of the sensors part which lights up as explained. closing pins 3 and 4 of the optocoupler mentioned, again the situation repeats that starts with the blank screen. The power supply of the optocoupler location "pc7702" is 9 volts, I think it is excessive as if there was no absorption by the integrated "ic7702 dda003a" but maybe I'm wrong. I try to follow the "AC_DET" line that refers to pin 9 of the "p9601" connector must be at a high level and in fact 3 volts appear, at pins 1,2,3,4, 13 volts appear and pin 11 i 5 volts.
  • kasfamily
    • Aug 2014
    • 772
    • Russia
    Re: sharp lc40le820e, il televisore rimane spento, non accende
    Hello!
    Power supply circuit
    Ciao!
    Schema di alimentazione
    • peterkos2
      • Nov 2020
      • 43
      • Slovensko
      Good day.
      Can you advise me on the problem?
      The TV Sharp mentioned above to the owner recently worked by turning itself off after three hours of watching, and then repeating it over and over again after 20 minutes.
      But now it cannot be switched on and the logo in the middle flashes twice at intervals. According to the service manual, this is a fault in the power supply board. After the measurement, I found that the PD connector was missing 13.2V.
      On Q7911 the SOURCE is fluctuating 14.2-14.35V
      on DRAIN is 0V
      at GATE is 14.19-14.38V
      Thank you for any advice
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        On the schematic check what voltage you have at SW because it looks like the mosfet Q7911 is not being turned on.
        Can you give the voltages on Q7921 and Q7061
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4367
          • Italy - Milan
          No good hijack others one's thread.
          • advant
            by advant
            02-03-2020, 12:25 AM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
          • gavenb
            Sharp LC-80LE661U 80 inch
            by gavenb
            Hi folks!
            I have a LC-80LE661U that had some interesting issues.
            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
            11-12-2023, 02:05 PM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
