Toshiba 37rv685d.
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    Toshiba 37rv685d.
    Firmware for a Toshiba 37rv685d, board V28A000938A1.
    To test.
    Other known issues?
    Thank's...
  • nomoresonys
    • 12206
    • U.S.
    Do you know it's a firmware issue? Do you need help trying to diagnose? If so what are your symptoms, maybe someone can help but definitely need more information.
    • cheeky2
      • Dec 2012
      • 337
      • uk
      The issue with these sets is the TV gets stuck in standby until you power cycle the TV. This is down to firmware which there is a German site which has the download links for all these Toshiba sets.
      If you searched on this site you would have found it!
      Eeprom dump thread! - Badcaps
      • cheeky2
        Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
        by cheeky2
        I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
        Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
        The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
        Details:...
        08-17-2023, 04:34 AM
      • anlu
        Vestel Firmware - Toshiba 32W133DN
        by anlu
        Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
        Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
        02-04-2023, 12:59 AM
      • DarrenHD
        Firmware for older Toshiba TV 22CV100U
        by DarrenHD
        HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
        I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
        https://support.dynabook.com/support...tentId=2865076
        Thanks!
        06-16-2025, 11:56 AM
        09-06-2024, 05:27 AM
        09-06-2024, 05:59 AM
