KDL-40NX713 LED blinks 4 times
  • marekk
    • Mar 2013
    • 36
    I would really appreciate any help to find out fault with this TV.
    I bought main av board form very similar TV 40NX711 and it did power up, but after half an hour it shuts down and again led blinks 4 times.
    Many thanks in advance
    Mark
  • AMRivlin
    • Jun 2014
    • 13
    Re: KDL-40NX713 LED blinks 4 times
    I have a KDL-40NX711 (4 blinks is the balancer)
    See my similar thread about 6 blinks due to a burnt out LED.
    https://www.badcaps.net/forum/showpo...2&postcount=10
    I now have 2 working LED Driver Boards, let me know if that is your issue.
    • marekk
      • Mar 2013
      • 36
      Unfortunately I don't know how to verify whether it is faulty LED driver or one of the LED in the backlight.
      • AMRivlin
        • Jun 2014
        • 13
        if you swap the driver board and it still has issues that should solve it.
        I can send you one of my extra driver boards. I paid $10usd. I am in London on July 10th and could post it from there.
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • brithepi2k
          Samsung UE75TU7020k No picture, Standby blinks 2 times
          by brithepi2k
          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
          04-23-2025, 10:05 AM
        • Samunggg
          Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
          by Samunggg
          I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
          I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
          09-06-2023, 06:39 PM
        • mecha1166
          XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
          by mecha1166
          I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
          07-01-2024, 05:47 PM
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
