fault with Sony LCD TV
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys bought this tv off someone and switched on to find it displaying most of the screen properly, i have attached video link to show fault, less than 2 minutes after taking this video meaning the tv would have only been switched on for less than 3-4 minutes the screen went normal but then after another few minutes is flickers lines horizontly as if the fault is trying to come back
    http://youtu.be/a71GdIq_c0E
    any ideas ? faulty panel ?
    Re: fault with Sony LCD TV
    Dead/faulty panel.
    I've never fixed a horizontal band panel failure with tab shims and haven't heard of anyone else succeeding either.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      Thanks Tom.
      • bammbammfran
        • Apr 2014
        • 476
        if the board that mounts to the lcd glass is on the bottom of the screen panel, then it probably has a side tab and not enough power is getting through that tab to get to the top of the screen because the tab is losing contact at the lcd glass side.
        if the board is on top of the screen, then a tab bond shim might work for a bit
        Would have to open it to get a better idea
        if you look at my video of this 24" panel, you will see what tabs / ribbons, I am referring to
        http://youtu.be/vI1tuQ_3FG0
        • sickboy
          Strange CRT Fault (Sony Trinitron M1410U)
          by sickboy
          This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
          11-10-2024, 05:02 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
        • sarry86
          sony dav-dz650 home theatre psu that has fault
          by sarry86
          Guys I am in need of your help, I forgot to discharge capacitors and went directly to check for the bad transistor, unfortunately I shorted this pwm ic, I'am not very good at troubleshooting hardware issues, can you guys help me know the similar ic to the ssc6200? It is a sony dav-dz650 home theatre psu that has fault, please help me...
          12-11-2021, 11:19 AM
