Re: Sharp LC-60LE810UN
Are you doing the reset correctly? In your first post you mentioned how you did the reset, but this is not the correct way to do it on this model. Here is the correct process.
To reset the lamp error detection off mode
1. Plug tv in.
2. While the 1-1 blink is acurring, hold volume - and channel ^ , while holding the two, press the power on button.
3. The v logo should shut off, release the buttons.
4. Press the power on button, if the short in the led is taken care of the tv should turn and function.
If this does not work, try to enter the service menu.
1. Plug tv in.
2. Press and hold volume - and input buttons, while holding them, press the power button.
3. Tv will turn on, with the letter k on the screen.
4. Press and hold volume - and channel down.
5. Service menu will appear, you should see lamp error in the list, set to 0 if it is anything higher.
The key to these procedures is pressing the power button while holding the other 2 keys. Older TVs you hold the keys down and plug the tv in. Which seems to be how you have been trying to do the reset procedure.
I also suggest installing your original main board into the tv before attempting the reset.
Hope this info helps.
-Nick
1. Plug tv in.
1. Plug tv in.
-Nick
