Toshiba TV 26AV502U
  • tonydix
    • Dec 2013
    • 31
    • Panama
    Toshiba TV 26AV502U
    The big problem power led flashes but otherwise set is dead.
    Smaller problems I cannot open the service manual I downloaded from elektrotanya I also dwonloaded the viewer but I get
    this error message.
    The ZEUS ENGINE cannot be located.
    This Service Manual requires ZEUS ENGINE.
    Any help much appreciated. Tony
  • R_J
    • Jun 2012
    • 9624
    Re: Toshiba TV 26AV502U
    I never liked that Dr. Zeus software, I found a 32av500 manual, not sure how close it is to what you need
      I run XP and I.E.8 to use ZEUS, I download and install:
      ZEUS http://elektrotanya.com/toshiba_zeus.../download.html
      And then I install AKAMAI NETSESSION INTERFACE DEMONSTARTION 10MB (INSTALLER.EXE):http://client.akamai.com/misc/demos/...cDownload.html due to Visual Studio Error when I was trying to install the AUTODESK DWF VIEWER. Then install AUTODESK 2013 DWF VIEWER.
      After that I am able to open the service manual.
      https://www.badcaps.net/forum/showth...t=12027&page=6 POST 104
      • tonydix
        • Dec 2013
        • 31
        • Panama
        Thanks guys the 32AV500U has a very similar power board to mine.
        AND following Budn's advice and 1 day of downloading I can now view the zeus service manual. Many thanks to both of you.
        I disconnected the board from the other boards, set up car light bulbs as loads and powered the power on with 5 volts via a 100 ohm resistor. All the voltages from the power board are correct.
        When the power board is connected to the main board the 5 volt supply cannot even manage 3.2 volts so i suspect a short ! But where !
        Any further ideas about troubleshooting this would be appreciated.
        Thank you guys
        • tonydix
          • Dec 2013
          • 31
          • Panama
          Somewhere the constant 5 volts must be changed to 3.3 volts to run the control unit but for the life of me I cannot find it ! The pages on the cicuit diagrames are named as follows and I dont know what all the abbreviations mean. So where should I be looking ?
          Precaution
          MAIN [2] DDR II SDRAM I_F
          MAIN [3] SIO I_F
          MAIN [4] HDMI I_F
          MAIN [5] Tuner & Demodulator
          MAIN [6] Audio In
          MAIN [7] SD Video Input
          MAIN [8] HD Analog Inputs
          MAIN [9] LVDS & Video Out
          MAIN [10] GPIO & Guest Bus
          MAIN [11] Test Block_NC
          MAIN [12] MISC & Connectors
          MAIN [13] HD770 Power
          MAIN [14] HD770 Ground
          MAIN [15] Class-D AMP
          MAIN [16] Power & Ground 1
          MAIN [17] Power & Ground 2
          MAIN [18] DDR II Power & GND
          MAIN [19] Reserved
          MAIN [20] MCU
          POWER [1] POWER
          KEY [2] KEY&IO
          IR [2] IR
          Many thanks
          Tony
            100 Ohms load on 5V only draws about 50mA, you need to use 10 oHms 5W to simulate 500mA current draw.
            • tonydix
              • Dec 2013
              • 31
              • Panama
              OK so here is the latest. Power board supplies all correct voltages when it is powered up with a resistor between 5 volt standby and pson and when no other boards are connected.
              Connect up the main board ( and nothing else) and 5 volt standby drops to 3.3 volts.
              All the caps on the mainboard test ok with esr meter.
              So is the problem with the mainboard or the power board not being capable of supplying the mainboard needs ?
              I need to put on some dummy loads on the power supply, particularly the 5 volt supply. Any idea what sort of load i should apply ?
              Tony
                Start with 10 Ohms 5W to simulate 0.50A current draw first, the power supply should be able to do 1A.
                • tonydix
                  • Dec 2013
                  • 31
                  • Panama
                  You are correct. The power supply copes with 1 amp fine and remains steady at 5.09 volts. So now I rig up a voltmeter across the 5 volt supply and an ammeter in the 5 volt supply to the main board .
                  The meters then go through a cycle every 10 secs or so volts go down from 5.09 to about 3.1 at the same time amps jump from 3 milliamps to well over 1 amp, then a second or two later amps back down to 3 milliamps and volts backup to 5.09. This cycle repeats continuously.
                  So I presume something on the main board is starting up leading to big current requirements and then safety in the power supply is shutting the supply down.
                  I am unsure about how to further progress this issue.
                  Many thanks for all the help
                  Tony
                    09-06-2024, 05:27 AM
                    Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    TOSHIBA LCD TV Manual & Schematic DL2944W LE1956W LE2456F LE1958W LE2458F DL2944AW LE1956AW LE2456AF LE1958AW LE2458AF
                    TOSHIBA LCD TV Manual & Schematic for models DL2944W / LE1956W / LE2456F / LE1958W / LE2458F / DL2944AW / LE1956AW / LE2456AF / LE1958AW / LE2458AF...
                    10-03-2024, 08:44 AM
                    Toshiba Satellite C55-A-156 Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Satellite C55-A-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C55-A-156 boardview and C55-A-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                    09-06-2024, 05:59 AM
