sony 32bx320 6 error code blink
  • Xerox90829
    • Jun 2014
    • Saudi Arabia
    Sony kdl32bx320, 6 error code blink, before that when i turn it on I saw sony Logo on the screen then it gives error code. Sometime if lucky tv is working. But right now set is completely not working and I dont see sony logo at all, it just give 6 blink error code. Service Manual say Inverter board problem or ccfl lamp. Guys any help to pin point which from the the part is defective. Thanks in advance.
  • jean paul thierry
    • Jun 2014
    • mauritus
    Re: sony 32bx320 6 error code blink
    please change the inverter board that is a common fault in this model
    • bammbammfran
      • Apr 2014
      • 476
      might be the inverter
      I just looked your kdl32bx320 up and found two on ebay
      BUT !!
      The pictures are completely different !!!
      So you should open it first to get a better idea
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • mauda
        Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
        by mauda
        I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
        Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
        05-21-2023, 11:56 PM
      • Storyteller12
        Sony XBR-65X900E 4 Blink Code
        by Storyteller12
        I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
        I don't work on Sony much but assumed it was backlights from what I read.
        Opened up the TV and tested all the backlights with led tester and the all work.
        I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
        So anyway to test these lights similar to the way we test...
        12-31-2022, 02:17 PM
      • bohaboha
        error code 0x80072f8f 20000 When widows upgrade to 10
        by bohaboha
        when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
        in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
        Error Code 0x80072f8f 20000
        08-30-2023, 07:06 PM
