Pioneer Kuro PDP-LX5090 7 blinks intermittent
  • mmartell
    replied
    Re: Pioneer Kuro PDP-LX5090 7 blinks intermittent
    Good for you, tom, you finally got that Kuro. You deserve it. Now don't spend too much time watching it
    replied
    I'm watching it in the dark, WOW! The picture is real good. But it does have the red haze I will need to fix. Also apparently you can tweak the V presets in the service menu to get down to 9.5G black level, so I know what my project is when I get it on the wall proper.
  • tw2005
    replied
    Aside from the clipped ground lead, it looks like BA18BC0WFP will fit (the tab is still grounded, which is probably the only important thing.) It's available from Farnell.
    Congrats, you got your KURO
    Got a feeling you may find something like BA18BC0WFP on some Panasonic DG boards, TNPA3519 as an example.
  • vinceroger69
    replied
    any time you want prices from that site let me know i have my log in details again now they are cheap on some things and expensive on other bits but there again its a independent business so probs high over heads.
    replied
    Farnell is cheaper TBH... I have to get some parts from there and I do want to order a few more than one.
    Thanks for the link though.
  • vinceroger69
    replied
    is that expensive? its £4.95 plus £2.95 postage plus vat
    replied
    Ah, I see it now
    http://www.wiltsgrove.co.uk/product-...=NJM2846DL3-18
    thanks
  • vinceroger69
    replied
    link works for me? its the same part number you gave in you post MJM2846DL3 1.05A 1.8VOLT T0252-5 IV REG LDO
    replied
    I can't see anything there?
  • vinceroger69
    replied
    tom does this look right?
    http://www.wiltsgrove.co.uk/search-results.php
    replied
    replied
    Freeze spraying regulator brought it back to life, this is looking like a nice one. Just need to find NJM2846 in the UK.
    replied
    Hmm, sounds potentially risky to me, unless it was very cheap I wouldn't take the risk.
    The IO board and main logic board are worth about $150 total, the sustains and PSU are worth very little, as they rarely go bad.
  • Caleb
    replied
    On the add it says it is intermittent, only on the top 3" and shows itself on white backgrounds. I did find the ics availible I thought it sounded like an open in one of the ics. the more common red tint appears to be on black and affect the whole screen.
    replied
    Bingo
    NJM2846 on board 1.8V regulator
    Working = 1.79V
    Faulty = 0.01V, control signal & Vin still present (3.3V)
    On Audio_IO board
    replied
    Originally posted by Caleb View Post
    Lucky you, what did the fault end up as? Ive been searching for one of these in my price range without any success for some time now
    edit just looked again and found one for 250 mostly working has purple haze on top 3" of screen, do you think the buffers are failing? and are they available?
    Purple haze is actually a common fault - look up "Kuro red tint".
    This TV has it very faintly, it is fixable, it requires an RS232 terminal. I will do it after the repair. You have to fire some commands at it, to reset some type of internal counter.
    The buffers are NON-REPLACEABLE. They are bonded to the panel via soldered ribbon . But you could conceivably replace an IC on the buffer board. I think with some hot air, you might just be able to remove the buffer ribbon - there is only one and it's a long one. But I wouldn't want to try it.
    replied
    It's intermittent, so I have to fix it still. It just powered up from cold.
  • Shinju
    replied
    Iron Man!
    Nice score tom!
  • Caleb
    replied
    replied
