Need info samsung un75nu6900f mainboard
  • HelpMeRepair
    • Jun 2022
    • 62
    Hi , I was asking myself if someone know the value of the transistors and capacitor that most people sell in there repair kit for this tv psu board
    thanks in advance
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    thanks in advance
    The value isnt in the parts themselves but rather the knowledge of what's needed to make the repair as well as the time saved sourcing said parts individually.
    Also these curated kits will include descent quality parts that are spec'd correctly.
    It may also include instructions on how to get the job done for laymen.
    Hope this helps and good luck.
    • HelpMeRepair
      • Jun 2022
      • 62
ID:	3516629 Click image for larger version
ID:	3516628 Click image for larger version
      thanks for your wisdom !
      I'm looking to replace those 3 parts I'll do my research on mouser and Digi keys
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Third picture doesn't show up so don't know what it is. But here's for blue caps. Your MOSFETs are likely blown also and a fuse.
        https://www.amazon.com/Hilitchi-150-...s%2C109&sr=8-1
        • HelpMeRepair
          • Jun 2022
          • 62
ID:	3516661 I have looked around , and tell me if I am wrong guys , but this mosfet can replace the one ont the board
          PJMH190N60E1_T0_00601 Panjit International Inc. | Discrete Semiconductor Products | DigiKey
          • HelpMeRepair
            • Jun 2022
            • 62
            thanks , I'll keep that in mind for future repair
            • HelpMeRepair
              • Jun 2022
              • 62
              thanks in advance
              i meant MOSFET not transistors , oops
              • HelpMeRepair
                • Jun 2022
                • 62
                part received and swapped , board work A1 , thanks for your help guys ! 😀
                ---> the package of the mosfet I chose was different then original , but I made it fit and have a nice contact surface so the temperature transfer to heatsink already in place is good. ( proper siting and thermal glue )
                  09-07-2024, 05:50 AM
                • Mark D
                  Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                  by Mark D
                  The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                  10-29-2024, 03:15 PM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                • bohaboha
                  ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                  by bohaboha
                  Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                  04-19-2025, 01:47 PM
                  09-06-2024, 11:40 PM
