UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
  • Yanleb
    • May 2017
    • 102
    My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
    Disconnecting the main board from the power supply makes the backlight come ON.
    I did disconnect the panel cables and the WIFI modules, the board is still dead.
    I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
    Thanks.
  • lotas
    • Jan 2016
    • 4813
    • Russia
    Yes, I can fix it (dump) for you. Yes, it's true
    • lotas
      • Jan 2016
      • 4813
      • Russia
      Can't read dump or don't have a programmer?
      • Yanleb
        • May 2017
        • 102
        Thanks lotas, I have a programmer. Here is the dump file.
        Where did you learn how to fix the dump files?
        • Yanleb
          • May 2017
          • 102
          For writing back the IC, I use the MiniPro TL866CS. I see registers 0xFC and 0x42 instead of registers 0x88 and 0x42. Does it make a difference?
          Click image for larger version  Name:	image.png Views:	0 Size:	24.2 KB ID:	3510334Click image for larger version
          • lotas
            • Jan 2016
            • 4813
            • Russia
            Yes, your dump is damaged, I fixed it. Registers should be 0x88, 0x42! (Status Register #1 0x88 (SRP0 BP1),
            Status Register #2 0x42 (CMP QE)
            Try it.
            Here is an example of how to write dump correctly.
            In the program:
            1. Click "Detect Chip" and select W25Q40CL and "Select IC".
            2. Click "Unprotect".
            3. Click "Clear IC" and "Yes".
            4. Click "Open File" and select your corrected dump.
            5. Press "Program IC" and "Yes".
            6. Click "Verify IC".
            7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE and press "Write" and "Yes"
            7. Close the program. Ready.
            • Yanleb
              • May 2017
              • 102
              Thank you very much lotas. The TV is working perfectly now.
              • lotas
                • Jan 2016
                • 4813
                • Russia
                Ok!
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • reessi
                  JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                  by reessi
                  I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                  You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                  Years ago it had some bulging caps...
                  04-26-2021, 11:42 AM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • Mirenia
                  Samsung UEMU6199U - no Standby - bad Firmware?
                  by Mirenia
                  I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                  Voltages on the power supply board is okay. Backlight test is also okay.
                  I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                  So I think my TV has exactly this issue.
                  Can someone please fix the dump?
                  And how do you do that?
                  As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                  05-12-2025, 06:13 AM
