Samsung 32" LCD flickering and double images
  • cheapshot
    • Jul 2012
    • 41
    • Bahamas
    Model # is LN32C450E1DXZA. Please see attached...(sorry it is not the best quality). Cuts on fine but top 3/4 of the screen appears to be scrolling and flickering. Any ideas where to start here?
  • cheapshot
    • Jul 2012
    • 41
    • Bahamas
    Re: Samsung 32" LCD flickering and double images
    Anyone here know where to start with this one?
    • proman28
      • May 2014
      • 9
      t con board replace it
      • cheapshot
        • Jul 2012
        • 41
        • Bahamas
        Please see attached picture of TV with cover off. Only board here resembling a TCON is actually a thin one at the base of the unit. This board has factory tabs to the panel itself and i cannot change.
        • bammbammfran
          • Apr 2014
          • 476
          check your voltages from the power supply to the main board.
          Under the large heatsink on the main board is a chip that might be the culprit especially if it is a bga chip
          • cheapshot
            • Jul 2012
            • 41
            • Bahamas
            Tested all voltages fine. 12v, 24V and 5V supplies good. On the pic, the TCON board cant be seen but it is underneath the panel base. This part is not replaceable no? It has factory tabs connected to the LCD itself.
            • cheapshot
              • Jul 2012
              • 41
              • Bahamas
              Also this issue with the scrolling and double images comes up right away as soon as the TV is turned on. No warm up needed.
                Likely cause is bad panel, small chance of LVDS interface problem or main board fault.
                No T-con in this set, it's built into the panel.
                • cheapshot
                  • Jul 2012
                  • 41
                  • Bahamas
                  Thanks Tom66 for that. Another bad Samsung panel I'll move on from this one!
                  • exsonyexpert
                    • Feb 2012
                    • 20
                    hi please check voff on t-con board(board at the bottom of LCD) voff is -19 v if not present replaced max17XXX
                    • bammbammfran
                      • Apr 2014
                      • 476
                      this link is not exactly your board, but it should fit
                      If you look at the picture you will see the type chip that is under your largest heatsink.
                      this is a good place to suspect issues
                      http://www.ebay.com/itm/Samsung-BN96...-/171322973081
                      • cheapshot
                        • Jul 2012
                        • 41
                        • Bahamas
                        Thanks guys. I will check on the board replacement. I will check the voff voltage and post back
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
