LG 50PS3000 Pink/Red Haze and Grainy Picture
  • mrsweet1991
    • May 2014
    • 5
    • England
    Hi All,
    So I have the 50" LG PS3000 TV that has developed red haze (which looks to me more like a pink haze). After doing some research I purchased a repair kit that contained a number of parts to solder on to the controller and z sus board. The Z sus board had a total of 9 parts replaced which where:
    Q13 / Q14
    Q15
    ZD201
    R201
    R209
    R457 / R458
    C201
    And also the controller board had these replaced:
    C8
    C9
    C14
    C15
    C31
    C39
    C652
    C653
    Initially the red haze seemed to have disappeared, however the picture was very grainy. Once 3 minutes had passed the pink haze kicked right in and was back to its normal self. I turned the TV off completely and re-tried, same thing.. grainy picture and after warming up the pink haze kicks right in.
    I have no problem purchasing a new board, but I need to get some advise as to which board or boards need to be replaced.
    Any help would greatly be appreciated.
  • mrsweet1991
    • May 2014
    • 5
    • England
    Re: LG 50PS3000 Pink/Red Haze and Grainy Picture
    Bump.
    • anotherdude
      • Feb 2013
      • 488
      maybe go over your soldering make sure there all soldered correctly I had a bit of trouble with the small caps on the control board, also may sound stupid but check you have them all in the correct place/position polarity etc
      I had trouble with the small diode as it's directly inbetween a heatsink and lots of other parts, I ended up soldering it to the backside instead
      https://www.badcaps.net/forum/showthread.php?t=33311
      • mrsweet1991
        • May 2014
        • 5
        • England
        Thanks for the reply, I'll go back over them again and double check. Also I was looking in eBay again for a cheap z sus board and I come across another repair service. In his description he states
        "Output mosfet transistors (under small, black heatsink) will continue to run hot after switch-on causing premature failure of the board"
        Maybe this is something I should look in to as well, the reason being is the pink haze kicks in only after a period of time which to me sounds like what the guy is on about with the MOSFETs heating up.
        I wouldn't even mind buying a new board, but on a few threads I've heard the y sus board being mentioned as well as some others so I can't buy the z sus board with confidence. Would you say the z sus is the likely culprit for the grainy and pink haze or could it be something else as well?
        Many Thanks,
        Dan
        • anotherdude
          • Feb 2013
          • 488
          Many Thanks,
          Dan
          on my thread tom66 said it was the z-sus, I bought the kit fitted it and never had the sparklies or pink/red haze again
          can you link to the kit you purchased?
          this is the one I bought http://www.ebay.co.uk/itm/271325575779
          • mrsweet1991
            • May 2014
            • 5
            • England
            Hi again,
            Exactly the same mate, so I suppose it could be very likely that something has been soldered wrong. Well I'll have a bash and retrace my steps, and if all else fails maybe take a good few close-up pics of the z sustain board to see if anyone can spot something I've perhaps done wrong.
            And thanks for your help, I appreciate it
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              LG's are known for having a red-dot/sparklies issue, sometimes careful adjustment of Vs, SET-UP/SET-Dn can cure it most times a control-board firmware update is needed though...
              TELEFIX
                AFAIK it doesn't apply to these using a 50H3 panel, too new (2009 generation)
                • YellowJacket
                  Asus VX238H - pink area over picture
                  by YellowJacket
                  Hi friends,
                  I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
                  I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...
                  08-17-2023, 11:45 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                  Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                  09-06-2024, 09:30 PM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
