Samsung ue40c7000
  • sordids999
    • May 2013
    • 2152
    Samsung ue40c7000
    ok my friend bought this tv round today and asked me to have a look at it he bought it off a guy on facebook it looks to me that the tcon is faulty due to the images some times goes solarized but it may also be the panel so looking for more advice please
    p.s also when i took off the back cover ive noticed that someone has glued on 3 one pence pieces to the main board any ideas why ?
    thanks
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung ue40c7000
    probably the soldering under the chips has gone and hes tried to aid cooling the adding the copper well thats my guess.
      Could you show us a picture or video of what it does when it is faulty?
      Are user menus etc. affected too?
      • sordids999
        • May 2013
        • 2152
        https://www.youtube.com/watch?v=ig5yVes591Y
        @tom as you can see in the video solarized images and sometimes lines of blocks on screen but you cant see that in the video
          Hmm, unlikely to be panel going by what it looks like. Have you checked the LVDS cable is properly seated both ends, no damage, bent/burnt pins, etc.?
          Access service menu: from standby press: Info Menu Mute Power on remote, then when service menu pops up, select SVC, then select Test Patterns. See what, if any, difference there is between GENOA-P and NAPOLI patterns, and if there are other generators present check them too.
          GENOA-P fault only: Main board pattern generator. Fault on main board or LVDS cable or T-con (T-con is unlikely but cannot be 100% ruled out.)
          GENOA-P & NAPOLI fault: T-con board pattern generator. Fault on T-con board.
          • sordids999
            • May 2013
            • 2152
            im checking the lvds cable now tom ive uploaded some pictures to show you that when i enter test pattern thats the only options im getting in service mode
              Do you have options under CONTROL or CTRL? I am going by the US service guide, I don't have the UK one for this model.
              • sordids999
                • May 2013
                • 2152
                picture uploaded
                  You have to press "OK" to select Control option.
                  According to the EU service manual you should have FBE Pattern Sel, and Logic Pattern Sel. http://elektrotanya.com/?q=showresul...oria=&kat2=all
                  Try selecting "Panel Auto Setting" and pressing OK, I think the panel options may be wrong. Also try a Factory Reset.
                  • sordids999
                    • May 2013
                    • 2152
                    yes tom i know selected the control option then you see the following
                    EDID
                    SUB OPTION
                    HOTEL OPTION
                    SHOP OPTION
                    SOUND
                    CONFIG OPTION
                    • sordids999
                      • May 2013
                      • 2152
                      Ive also checked the lvds cable cant find much wrong with it
                      • sordids999
                        • May 2013
                        • 2152
                        also tried factory reset still the same the picture has a orange solarized effect plus some times you have slightly light white lines going across the screen
                          Since the behaviour in the service menu is different to the service manual, someone has been fiddling with this TV more than adding pennies to the chips (seriously, who thinks that's a good repair technique?!)
                          I think I see a Samsung panel sticker. What is the Panel Option under "Option" on the service menu? It should be AMLCD or SAMSUNG and the INCH OPTION should also match.
                          Did you try the "Panel Auto Setting" option?
                          • sordids999
                            • May 2013
                            • 2152
                            PANEL TYPE 40A2UF7E
                            LOCAL SET EU_AII
                            MODEL UC7000
                            TUNER SEC_T2
                            FRNT COLOR T-M-BRN
                            and if i try the panel auto setting it goes to wait then quickly back to failure
                              Does the panel sticker say "LTF400HQ02"?
                              • sordids999
                                • May 2013
                                • 2152
                                yep
                                  Hmm, try changing it to 40A1UF0E, any difference?
                                  • sordids999
                                    • May 2013
                                    • 2152
                                    no tom still the orange skin effect and solarized images
                                      Any change to the test pattern options is what I meant, sorry.
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        no tom
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
