Samsung pn50c450b1dxza
  • jdoncouse
    • Oct 2013
    • 72
    Tv turns on has sound and no picture when turned off you see a quick second where the tv panel shows color like in these pictures
  • tw2005
    • Oct 2011
    • 6458
    Re: Samsung pn50c450b1dxza
    Could be bad XMAIN.
    • jdoncouse
      • Oct 2013
      • 72
      oh yeah actually its when it turns on.. sorry about that one .. it turns on.. color on pictures show up and then it disappears. but i'll look into xmain
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Check the Y-buffer for a bad buffer IC. Search on youtube "test buffer board shorts" and its done the same way with almost all buffer boards. Usually if the panel turns on and glows with sparkles for a second itll be a bad buffer IC.
        Looking at the top of the screen I could see some horizontal lines of pixels --> these can either be a:
        --bad connection to panel (reseat the connections to the buffer board)
        --bad buffer IC, (however usually when the IC fails it would have shorts on it. The only time it would cause those horizontal lines its if it has bad solder connections or just fully open circuit (which is extremely rare))
        --just a bad panel itself with damage to the connection to the panel (this is unrepairable and usually the most likely case unfortunately)
          Check panel very carefully for cracks esp. around the edge there was one on the forum recently doing something similar with a crack in the panel.
          • jdoncouse
            • Oct 2013
            • 72
            from the woman i got it from they said that samsung replaced the panel 2 years ago under warranty and they was watching it yesterday and it just started doing what it is doing i was really figuring it was a board more than panel. i havnt ever touched a plasma before so i didn't know if there was a huge difference in it all..
              Picture quality is usually a lot better on a plasma; also you get a bigger screen per $ spent with plasma.
              The theory of operation is almost completely different and in general more complex, but repairability is typically better than an LCD.
              • jdoncouse
                • Oct 2013
                • 72
                small update.. got a new xmain just because it was cheapest.. now when i turns on i get a hell of alot more of the pixels when it flashes them. Almost enough to cover the full right of the screen. gonna pull out the buffer board and test that next and buy a new y main since it's pretty cheap too. then just pray lol thanks guys for the help
                • jdoncouse
                  • Oct 2013
                  • 72
                  dicking with it some more i checked the voltages on the sticker and they are all good. I heard a zappy kinda sound when the tv cuts on from the y main board. it's the big yellow thing on it. when the pixels cut out again it stops.. so thinking it's the y main defiantly
                    Did you check the -Vsc on the Y-main?
                    • jdoncouse
                      • Oct 2013
                      • 72
                      yes all of the voltages where right actually.
                      • jdoncouse
                        • Oct 2013
                        • 72
                        ok i pulled out the buffer board and did the test and i got a short on the third ic from the top.. would this cause the tv to do everything described?
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          Yes the buffer board would highly be your problem as I described on post #4
                            09-07-2024, 05:50 AM
                          • Egidio85
                            Samsung UE55F8000SZ Turns on and off immediately
                            by Egidio85
                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                            This defect happens continuously, hearing the classic click of the relay every time.
                            Power supply board BN44-00636B
                            disconnecting the mains and lamps from the power board always causes the same problem.
                            Is it normal that without anything connected this power supply turns on and off cyclically?
                            any suggestions on what to check?
                            thanks in advance
                            03-11-2025, 12:45 PM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
