Tc-p54g20
Assuming...7 Photos -
by prodigy83My reference only: TT10141.
Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
Mosfet specs are as follows:
Chip markings:...1 Photo -
by corrizeHello, I have a basic power board (from DSLR camera), this board convert 12v in some other voltages (there is no charging chip). This board is disconnected to other, so it feed nothing, the outputs should be open lines.
When I plug the battery (12v), I measure a weird behavior…
I found a mosfet , with 12v at source and gate, and the voltage decrease very slowly at drain : 8v… 7v… 6v… I measured with meter source-drain : 45KOhms, so can I deduce surely the mosfet has a leak (and it is dead) pls ?
The mosfet datasheet, but it's basic one.
https://pdf1.alldatasheet.co... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
- Loading...
