Sony Bravia KD-50X690E NO SOUND
  • x_orange90_x
    • May 2015
    • 762
    Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
    Has anyone else had this happen to their tv?
  • alegatorul
    sony bravia kdl-43w756c, no power, no sound
    by alegatorul
    the charger brick has 19,2-19,3 vcc
    changed the inverter board same result.
    where should i start?
    cheers
    Yesterday, 10:00 AM
  • KYBOSH
    Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
    by KYBOSH
    Previous owner said TV just went blank one day.
    They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
    Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
    The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
    There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
    I just downloaded the Sony KD-75X7800F Service Manual and...
    11-19-2024, 10:12 AM
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • iglitare
    by iglitare
    09-04-2025, 07:13 AM
