Panasonic tx-p42s20e half screen failure
  • KORHAN DEGIRMEN
    • May 2014
    • 10
    • TURKEY
    Dear All;
    I have a problem with my 4 years Panasonic TX-P42S20E Plasma Television. You can see some posts below between me and tw2005 on site. I hope this thread helps everyone.
    https://www.badcaps.net/forum/showth...581#post444581
    We are to close to solve my problem.
    Thanks for tw2005. He knows well and helpful.
    Everyone can contact with me if needs.
  • armoured_smiler
    Panasonic Tx-40cx400b top left half screen not displaying correct
    by armoured_smiler
    Trying to work out if this is TFT problem or TCon issue.
    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
    04-08-2024, 03:40 PM
  • renech
    panasonic TH-42PC77U plasma television half screen problem
    by renech
    hello,
    I hope someone on this forum can assist me.
    I have a panasonic TH-42PC77U plasma television.
    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
    I have read some posts that suggest the problem is related to the boards on the left...
    12-12-2022, 06:53 PM
  • Zelek11
    Panasonic Plasma screen interference on left half of screen
    by Zelek11
    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
    10-14-2022, 04:54 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • canadaboy25
    Panasonic TH-50PX75U top half of screen blank
    by canadaboy25
    Hey guys, I was given a Panasonic plasma because the top half of the screen was black but the bottom half was still working normally. Sometimes the top half would flicker on and off. I tried reseating all the ribbons and cables thinking it was a loose connection but it made no difference. After I fooled around with it for a while it was working most of the time with only the odd flickering on the top half. There was no real correlation between my tests and it starting to work. I set it up and started using it and it was perfectly fine 98% of the time. I used it like this for a couple months with...
    09-02-2019, 03:57 PM
