PS50Q96HDX/XEU Clicking
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi all, This is the second time i've had this model in, Last time it was these components at fault F802, QX801, QX802, DX803, DX804, RX802, RX803, RX832, RX833, This set has similar clicking symptoms but all those components appear fine, all the caps look good and I've also removed and tested a few, What else could cause this fault?? Customer said it turned itself off one night last week and its just been getting worse, Now when powered up it stays on for about 2 mins then keeps clicking.
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Re: PS50Q96HDX/XEU Clicking
    Can upload pics if needed..
      Cold joints under those transistors is possible, also try isolating X- and Y-main boards.
      • Easky15
        • Sep 2013
        • 285
        • Ireland
        Thanks tom, I disconnected all other boards and still its clicking, I'll resolder those joints now to see if that helps..
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          QX801 N-Ch Mosfet 3.19v 2.50mA
          QX802 N-Ch Mosfet 3.03v 2.50mA
          Resoldered both and set now powers up everytime and seems to be staying on, I'll update the post if it fails but for now it's lookin good, solder connections didn't look bad but it appears that was the cause. Thanks again tom.. ;-)
          • Easky15
            • Sep 2013
            • 285
            • Ireland
            Worked all night and hasn't clicked once, ;-)
            • B0r1s
              Samsung UE49KS7000SXXH - fast clicking sound in standby mode
              by B0r1s
              PSU - BN44-00878A
              Symptoms:
              The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
              A weak clicking sound was coming from the transformer.
              Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
              Progress:
              After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
              01-17-2023, 04:58 PM
            • slimmy182
              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
              by slimmy182
              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
              Looking on google I found this:...
              01-14-2023, 11:55 AM
            • beetle1303
              Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
              by beetle1303
              I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
              On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
              01-13-2025, 08:49 PM
            • mikelu53
              Samsung UN60D8000YF Clicking BN44-0432A
              by mikelu53
              I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
              The set was working then not,then started clicking.
              Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
              Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
              A schematic or suggestion would be great.
              01-21-2023, 03:14 PM
            • bffargo
              2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
              by bffargo
              LG 60PB66550 NOV 2014
              PSU: EAY63168603
              PCB: EAX65359531 2013.11.01 Rev:1.0
              Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
              Symptom:
              While watching, just went black and started clicking relay every few seconds.
              Initial diagnosis:
              Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
              Deeper diagnosis:
              Pulling pins #1/#2 (Blue/Grey) from the connector housing...
              09-09-2022, 07:34 PM
