Samsung plasma DEAD......
  • grabcol01
    • May 2014
    • 24
    • U.K
    Hi all, Well what a great web site, just hope of some help!!!
    anyway in my drunken state one night I said yes I can fix a donated 50" samsung plasma tv, the standby blue light come on for a split second and then goes out, no other signs of life either, NO clicking of relays, also don't have 5 volts or 12 volts coming from psu pcb. Fuses all o.k, I know the t.v was in storage in a shed for 18 months...... should I get a repair kit from ebay or something else..?????
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung plasma DEAD......
    Model-number and pictures of its internals would be a good start!
    TELEFIX
    • grabcol01
      • May 2014
      • 24
      • U.K
      Sorry,
      Model. PS-50C96HD
      MODEL CODE. PS50C96HDX/XEU
      TYPE NO. CA50C9
      50 HZ, 480 WATT
      MANUFACTURE. SEPTEMBER 2007.
      S/N. Z5993SSP900124W.
      • grabcol01
        • May 2014
        • 24
        • U.K
        5 heatsinks, 3 transformers, No obvious knackered caps or dry joints..
        • grabcol01
          • May 2014
          • 24
          • U.K
          Also, does anyone know if Samsung are still honoring the known cap replacement scheme up to build 2008.... ??!! on the psu pcb...
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Pictures of Y-SUS/PSU and X-SUS?
            TELEFIX
            • grabcol01
              • May 2014
              • 24
              • U.K
              I'm reasonably confident that X & Y sus are ok. deffo no 5 or 12 volt from psu, no clicking... is it worth just changing all electrolitic caps.... I will post pic of psu tomorrow... Thanks for your input Alistair & I know its hard with out a pic to have a ref of what i have ... cheers
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Googling model-number has illustrated the chassis you have....
                Got one of those abortions in the garage!
                Randomly changing caps I suspect wont do a lot to be honest, No 5V--at all, as in No STBY 5V....?
                --Only cap worth changing I would think--would be that associated with the STBY 5V from the STBY supply reg....
                TELEFIX
                • grabcol01
                  • May 2014
                  • 24
                  • U.K
                  Do you have a pcb ref..., there is 5 volt on a test pin on pcb, but nothing at any connectors, what do you think about no 12 volts either ?!!
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    The 12V may only activate when the set is fully on--not sure on that, but wouldnt at the moment be too concerned about that.
                    The complete lack of a 5V at any output pin of the PSU is the main issue I think.....
                    --Trace back from the mainboard--the pins should be marked on that board....
                    TELEFIX
                    • R_J
                      • 9583
                      I just repaired a set simular to this, there was a shorted 30volt zener in the standby circuit near the 8 pin standby ic. Also the standby cap was bad
                      But your set might have a different board.
                      • grabcol01
                        • May 2014
                        • 24
                        • U.K
                        Here it is, the offending beast!!
                        • grabcol01
                          • May 2014
                          • 24
                          • U.K
                          R.J, what was the diode exactly, do you recall. Its the same board lay out !!!
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Hmm--That looks to have had a hard life....
                            --Maybe on most of the day--everyday in an over centrally-heated house, by the looks of the board discolouration!
                            The plugs are marked. Check the STBY 5V at the double-row socket bottom left of the board.
                            TELEFIX
                            • grabcol01
                              • May 2014
                              • 24
                              • U.K
                              No voltage present, do you know what diode zd8803 is spec wise or is there a schematic that i can look at on the web site as a pdf type thing......, I.m going to replace al caps as they are well know for a bad manufacture used by samsung.....
                              • anotherdude
                                • Feb 2013
                                • 488
                                i'd say you're just wasting time and money doing that, unless they are visually bad
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Aye--Replacing all the caps on spec is pointless--Unless you can confirm they are bad, and probably cost more than a working supply!
                                  Only ones worth doing are the two or three associated with the STBY 5v supply, as they are cheap enough--and always 'on'
                                  --To replace much more is a waste of effort and money at this stage.
                                  TELEFIX
                                  • grabcol01
                                    • May 2014
                                    • 24
                                    • U.K
                                    There is a GOD...... I've just had a final look before taking to tip tomorrow and like you said Graham as I have read on other sites, shorted out PS-ON & rtn pin next door and 2 quick clicks from relays, then a click as short released..... plugged all the leads back in to p.s.u.............. shove the mains lead in and click click and T.V is on.... all the menus work and no unusual looking lines or anything, just need to get a aerial lead up its back side and hopefully its a good one........ Maybe the relays just needed a good short....
                                    • cossiesmit
                                      • Jun 2014
                                      Hi grobcol01, have sent you a PM/email asking for help.
                                      If you could reply that would be brilliant. Cheers, Mark.
                                      • cossiesmit
                                        • Jun 2014
                                        No Need, found a dry joint next to the PS-ON and heated it up and bingo!
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
