PN58B550 is DEAD - Please help!!!
  • zukdj
    • Jun 2012
    • 104
    I just got a free Sammy Plasma model PN58B550 from my company, the TV was always mounted on a wall in a conference room and used intermitently, not to excess by any means. One day they went to turn it on and nothing, no blinking lights, no clicks, no power up sound. I took the back off and tested voltage to the power supply and past the first 2 fuses, that was the extent of my troubleshooting however power is flowing into the power supply. To the right of the power entry to the power supply there is a small unlit light bulb on the power supply board when power is present and passing into the supply. I assume this being unlit poses a problem with the power supply? I ordered a new power supply that I am waiting on, what else should I check for if this isn't the problem or am I on the right track?
    Re: PN58B550 is DEAD - Please help!!!
    That is a neon bulb used as a surge arrestor, will not normally light.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • Andreas_de
      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
      by Andreas_de
      Hello!
      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
      04-12-2025, 10:38 AM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
