Sony PVM-9045 - bad film capacitor stopped startup
  • japlytic
    • Oct 2005
    • 2086
    Recently, I received a Sony PVM-9045 which would not start up.
    After some time, I found the Horizontal oscillator frequency on Pin 5 of the uPC1377C sync IC was about 365kHz, way above the normal 15-16kHz range and therefore preventing any output on Pin 10 of the uPC1377C.
    Further investigation revealed that C517, a 0.0056uF polypropelyene unit was defective (it was the timing capacitor for the Horizontal oscillator) and replacing it restored operation.
    Notably, the defective unit had a significant cosmetic defect, even though it was within tolerance when measured with a capacitance meter out of circuit, which means this capacitor could have been leaky.
  • WatchItFool
    Sony FVS1000 film scanner telecine Roms
    by WatchItFool
    looking for ROM files / updates, software, and CAD files. Everything really
    i have most, but not all, available documentation by sony pn.
    What was all listed in the sony pro reference library?
    I dont know of any places to look. will anyone name names?
    08-04-2023, 12:58 AM
  • Prolog
    RTX 3080 FE Identifying capacitor
    by Prolog
    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
    I hope these photos make it clear which component I am referring to:
    (yes, the soldering is a bit botched from removing the blown one, I know)
    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
    12-01-2024, 08:27 PM
  • chth96
    If I replace with inferior capacitor, Is it No harm to other IC components at all?
    by chth96
    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
    I know that these capacitor will not last as long as nichicon capacitor...
    12-22-2023, 04:34 AM
  • motorahead
    Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
    by motorahead
    Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
    After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
    10-21-2023, 03:50 PM
  • chth96
    How can I test non-polarized capacitor?
    by chth96
    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
    06-02-2024, 07:31 PM
