Hannspree service menu code
+ More Options
Posts
  • mickcan1
    • Jan 2014
    • 6
    • n.ireland
    Hi would anyone have the code for hannsspree service menu thanks
    Re: Hannspree service menu code
    Varies but SOURCE 3690 and SOURCE 2580 have worked for me for other off-brand Chinese TVs.
    • mickcan1
      • Jan 2014
      • 6
      • n.ireland
      Thank you Tom will try them now
      • mickcan1
        • Jan 2014
        • 6
        • n.ireland
        Didn't work any other codes I could try please
          I'm not aware of any others sorry.
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • ARGO
            Vizio service menu code
            by ARGO
            There are a lot of different codes on internet but they doesn't work for all modern Vizio TVs.
            Here is tested code to enter service menu (factory menu), tested by me on D-series and P-series:
            MENU-1-9-9-9-Return.
            (Retun is a button with round arrow on remote)
            Overall the menu is useless because it doesn't allow to change panel and LVDS settings...
            If anybody knows any other codes for Vizio, post it here, please.
            By the way, Philips TVs uses the same main boards with same service menu access code......
            06-10-2020, 08:16 PM
          • tusiime
            How to access Vizio m652i-b2 service menu
            by tusiime
            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
            09-15-2023, 09:57 AM
          • intercepter
            JVC LT-32CA120 service menu
            by intercepter
            I have JVC LT-32CA120
            Board:Vestel 17MB171
            I need rotate screen.It is possible in service menu and how to enter service menu?
            Thanks.
            12-10-2024, 10:29 AM
          • sohail5307
            I need how to open this Dell service menu option in dell latitude e6420
            by sohail5307
            I need to open service menu of Dell laptops like image in attachment
            Ignore my English
            I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
            01-13-2023, 05:56 AM
