42pc1d control board swap
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    brought this tv and fixed it as in other post but was left with the red sparkle problem so far have found two people on here willing to flash a new firmware on the control board but thought i would look on the net for a newer control board so found one on ebay and won it for £2.20 but on the auction it says will not fix the red sparkle problem http://www.ebay.co.uk/itm/2614520905...#ht_728wt_1305
    yet on another site someone posted
    I got my LG 42PC1D plasma back, and replacing the controller board fixed my red dot issue. I inspected it both with no signal, as well as while watching both SD and HD content. I couldnt find any red dots. So it fixed the problem, hopefully for good. I also had problems with HDMI sound cutting out, and they replaced the main PCB board for that, and thats okay too in case anyone has that problem. Part and part number are below for red dots:
    Part: Controller PCB
    Part # : 6871QCHO77C
    now that part# is the one ive just won so do you reckon it will fix the red sparkle problem for me? many thanks
    Re: 42pc1d control board swap
    The sparklies problem is caused by the plasma panel wearing out; it drifts and the drive waveforms (generated by the Y-sus and Z-sus under control of the control board) are no longer sufficient for good picture quality.
    An update to the control board is required which fixes this issue, by uploading new firmware designed to compensate for the panel aging.
    It's possible a new board will have an earlier life timer, so for a few hours or days it might work right. But it is not the correct fix and the sparklies will return within short order.
    You need to get the board flashed.
    • azza1234
      • Nov 2013
      • 124
      • united kingdom
      ok thankyou for your help
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
        Linear Garage Door Opener Control board took a crap install a new control board back normal
        I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
        02-08-2025, 06:52 AM
