Zenith/LG z50px2d new PSU swap-in...
  • SlickClick
    • May 2011
    • 91
    Picked up this 50inch user said the tv started out fine for years then one day they had to press the power button twice, then had to hold it for a few seconds, eventually they said it took an hour holding the power button on for it to come on....
    Took it home popped it open there was about 13 blown caps on the high power side between the transistor sinks... I found a guy locally who had a "brand new" PSU... I inspected the board doesnt look like a screw ever touched the board not a hot spot on it looks good...
    Now when I power on the unit I get 3 green blinks and then back to red standby...
    I cant get the PSU to stay on long enough to test voltages out...
    I suspect that because the PSU is supposedly Brand New that maybe i have to set the Vs voltages higher; but how do i get the board to stay on to set these values..?
    Any switching bypass or pin tricks to get the PSU to stay on so i can check and set Vs values..?
  • SlickClick
    • May 2011
    • 91
    Re: Zenith/LG z50px2d new PSU swap-in...
    Been looking all day... Downloaded the service manual from toms archive...
    The image for 4.2 is so blurry I cant tell what it says to do...
    How do I get this PSU to turn on without the mainboard connected..?
    F-It imma just start touching shit together and see what happens...
      That's one surefire way to fry shit.
      I had a 50" LG PSU which wouldn't fire up until I tweaked the Vs pot slightly up.
      • SlickClick
        • May 2011
        • 91
        I found that if i bridge the the blue wire to the main board with the first white wire next to it the PSU stays on... However I am getting no voltages out of it... so i am guessing there is a second stage that i cant figure out how to get on or the board is just bad...
          Both PS-ON and VS-ON need to be turned on. Make sure the panel or sustains aren't connected.
          • SlickClick
            • May 2011
            • 91
            Yea i disconnected everything from the PSU but the mainboard at first and get 4 green blinks i believe....
            even hooked up that way when it clicks briefly i only get less than 2v on Vs...
            P801: When I jumper ac-on to rl-on the PSU high side clicks on...
            i tried touching ac-on to vs-on but does nothing... what voltage is required to turn vs-on to on state..? 5v 12v..?
              AC-ON is an OUTPUT from the power supply, not an input. Use 5V Standby as your source. Need to turn on RL ON, M5V ON, 3V3 ON, and VS ON.
              • SlickClick
                • May 2011
                • 91
                I am getting all good low voltages but no Vs or Va voltages... Vcc is at 4.4v
                there is no 3.3v there is POD... I tried to take a picture with this gopro camera I bought to put down my septic pipe but it sucks so bad i cant even get a good shot... -ie dont buy one unless your skydive or want a cheap camera snake lol-
                just did some more tinkering and found that if i hook up the low voltage connections i get fans and such on but when i hook it to the main board 3 green blinks but if i hook it to the main board with the bypass wires all in it does a start up like normal with the green light but still no high voltages at all at any point...
                is there something that turns on the high voltage that i am missing..?
                  VS ON turns on the Vs & Va...
                  • SlickClick
                    • May 2011
                    • 91
                    after doing a bypass type startup a couple times i removed all the jumpers and TV is starting up fine now...
                    it didnt wake up the PSU fully i guess until i had it hooked and bypassed on the mainboard... geting 59 and change on one and 198 on the other...
                    too bad the electronics store wants $2.50usd/ea a cap; i could have likely fixed the original but for $30 for a new PSU just made sense... the whole tricking it into thinking its ok was another story... cause i consistantly got red - 3 green blinks - red for 2 days straight...
                      Don't use caps from some electronics store unless they are high quality, the average shop does not supply good caps (Panasonic FC/FR/FM, Rubycon YXF/ZLH, Nichicon PW/HE, etc.) DigiKey or Badcaps.net has good quality caps available at reasonable prices.
                      • SlickClick
                        • May 2011
                        • 91
                        he had sanyo caps... but at $2.50 a pop im good... I needed like over a dozen caps too... so its not worth fixing the original PSU...
                        • proxneo
                          Recapping Sony ICF-SW55 - verifying cap values
                          by proxneo
                          Dear reader
                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                          At the moment, I have selected replacements based on the following list of values:
                          3 x 470uF 10VDC
                          3 x 4.7uF 35VDC
                          4 x 47uF 50VDC
                          8 x 22uF 6.3 VDC
                          1 x 220uF 6.3VDC
                          5 x 100uF 6.3VDC
                          Which...
                          06-21-2023, 12:38 AM
                        • pete g
                          zenith plasma tv. the model is Z50PX2D.pix problem
                          by pete g
                          hi, i have a zenith plasma tv. the model is Z50PX2D. i really love this tv. as of late its coming on with 6 vertical lines of white dots. they flicker, the audio seems to affected also with static sounds. all other aspects of the pic are good. i have good color, and no other problems with picture. can someone help? thanks.
                          06-18-2022, 12:10 PM
                        • pete g
                          zenith plasma Z50PX2D
                          by pete g
                          Hi, problem is 6 vert lines the width of the screen. Lines are filled with round white dots, also static in sound when dots vary. Anyone know of this problem?
                          06-19-2022, 05:32 PM
                        • Kobok
                          Different (lower) resistor values on PCB?
                          by Kobok
                          Dear Alls,
                          For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                          09-19-2022, 07:30 AM
                        • DeXXter
                          HP VICTUS 16-d0500la Some Values
                          by DeXXter
                          Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
                          This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
                          03-13-2025, 03:16 AM
