Samsung PN51D550C1F - Clicking...HELP!!!
    Re: Samsung PN51D550C1F - Clicking...HELP!!!
    Could you remove the X-main board and take a couple pics of the bottom, green side of the board.
    • ptheman12345
      • Dec 2012
      • 42
      • usa
      I've attached a pic of the bottom of the X-Main
        OK, see picture.
        Set multimeter to diode mode. This is marked with a diode symbol -:>|-
        For each circled device:-
        Mentally number the pins 1-3. Order isn't important.
        Put your red probe on pin 1, black on pin 2. Note reading.
        Repeat for pin sets 1-3 and 2-3.
        Any readings that test below 100 are a sign of a bad device - make a note of any.
        If no bad readings are fine you should be good to go on replacing Y-main only and fix your TV for $40.
        After doing this, make sure to download Samsung firmware update from the Samsung website, you will need a USB stick to install it. There is a tech bulletin about a firmware bug on the control board damaging the sustain boards (X- and Y-main.) Installing the update should prevent repeat failure.
        • ptheman12345
          • Dec 2012
          • 42
          • usa
          OK, see picture.
          When doing pins 2-3 on certain diodes, I would get a reading of 1. I'm prettying sure I followed your instructions correctly. Would that mean the board is bad?
            Is that "1" the same reading your meter gives when the probes aren't touching? If so, that's fine.
            • ptheman12345
              • Dec 2012
              • 42
              • usa
              #26
              Yes, it's the same reading I get when the probes aren't touching.
                OK, if that's all you got, you should be good to go on just getting that Y-main replaced.
                • ptheman12345
                  • Dec 2012
                  • 42
                  • usa
                  #28
                  I just installed the new Y-Main, but the TV still isn't working properly. The relay clicking stopped, but nothing is appearing on the screen. Could there be another board that is bad?
                    Do you have good Vs and Va?
                    What is the light on the control board doing - one blink approx every 1~2 seconds or a slower blink every 5~7 seconds?
                    Can you check the Vsc voltage on the Y-main.
                    Where did you buy the board from? Did they test it?
                    • ptheman12345
                      • Dec 2012
                      • 42
                      • usa
                      #30
                      When I plug the tv in, at the first click, Vs is about 207 and Va is about 58. As for Vsc, it was about -195. The control board has a slower blink about every 5 seconds. I bought the Ymain from shop jimmy, so it should be working
                      • ptheman12345
                        • Dec 2012
                        • 42
                        • usa
                        #31
                        i also noticed that after replacing the old Ymain with the new one, the panel flashes once when plugged in
                        • ptheman12345
                          • Dec 2012
                          • 42
                          • usa
                          #32
                          Any suggestions??
                            Can you try this test on your buffer board?
                            https://www.youtube.com/watch?v=51SZ...Y&noredirect=1
                            If your meter does not have a continuity/beep mode, you can use the ohms mode and look at readings below about 200 ohms as being bad, but you will have to be a lot slower (about 1 minute per connector to make sure your meter doesn't miss any shorts.)
                            • Athhos
                              • Jan 2012
                              • 10
                              • Portugal
                              #34
                              Hi. I'm having a identical issue with my PS43D450 plasma.
                              This plasma when pressing the power button the led blinks twice stby 5X until the relay docks. The tv never comes on and resumes the previously mentioned. I did some research and with the X and Y plates off the tv keeps this symptom so I think the cause is the power supplyn board. The capacitors seem in good condition as well the photodiodes. Unfortunately I still cannot find the schematics for this PS "BN44 00442B" only identical models but it becomes difficult to follow any consistently idea. My knowledge in terms of plasmas is little or none. I would appreciate help me with the experience feedback from same or identical situations.
                              Greetings and thanks.
                              • General-lee1969
                                • Jan 2016
                                • 6
                                • canada
                                #35
                                Was this resolved with a y-main and y-buffer board?
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
