50 inch Plasma, bottom half blank, lines in the middle
  • keats11
    • Nov 2012
    • 88
    I have a Insignia Plasma NS-PDP50, which I picked up from ebay, near by.
    Basically, when you turn it on, the top half is mostly fine. There are a few horizontal lines across the screen, right in the middle. The bottom half is blank.
    Thinking that this is a buffer board issue, pulled the buffer boards and found no shorts. I also had a spare Buffer board lying around, which I installed out of curiosity, and the problems remained the same. From measuring the resistance from the top to bottom buffer board inputs, I see these as a short, in other words, they both get fed the same signal. So I am puzzled at this point as to what could be causing this issue. I have taken some pictures for you to see. Can anyone help?
    PS: This panel is shared by several other models: LG50PC*, Sanyo DP50747, Vizio P50HDTV, Zenith 50PC3* etc.
    Re: 50 inch Plasma, bottom half blank, lines in the middle
    It's probably a buffer board issue, but if the fault remained with the new board, it's not impossible that the panel has caused the fault. That being said, I've never heard of it on these models. Have you confirmed the replacement board was working?
    • keats11
      • Nov 2012
      • 88
      Tom: The replacement board was from another TV I have had in the past, probably an LG, but the same panel. Since there are no shorts in the BB, I am puzzled how the buffer boards could be bad. Also, if the upper buffer board is bad, wouldn't I expect to see a picture on the lower half?
        The buffer boards are the only boards which control the picture in the vertical axis.
        A chip can be bad on a buffer, which can cause no picture, or it can cause particular parts of the image to fail, which is what has happened in your case. It can be short or open, usually short failures occur but open circuit failures can too apparently.
        The one dead line makes me think shorted panel (damaging that one output), and the white area is due to the IC being "wounded" by the nearby failure.
        I'm not certain but the fact that you swapped two boards in is only pointing more to the panel. Sorry... Could be a worn ribbon, touching panel edge or something, so check that first.
        There is no other board that can cause such a specific fault.
        • tw2005
          • Oct 2011
          • 6458
          If you have a another known good upper board laying around, I'd try that. You can see DATA_IN test point as it enters the first buffer IC and daisy chains in and out of those and exits the last one for DATA_OUT for the lower board.
          I'm thinking from the display the last IC has failed on the top board and stopped the data from being passed on to the bottom board.
          • keats11
            • Nov 2012
            • 88
            After talking to you guys, I took a look at the buffer boards themselves. I looks like the numbers do not exactly match what they have listed on ShopJimmy. So it is possible that the people tried to change the buffer boards themselves, swapped them for the wrong boards which is why the TV is acting like this. I have ordered the replacement boards from ebay. Will post again once I receive the boards and test them out. Thanks to all.
            • keats11
              • Nov 2012
              • 88
              Just to bring this to a closure, I was able to get the exact boards for the Insignia (they looked exactly like the ones that were in there, and the part numbers did not match, which makes me wonder if the previous owner had tried to replace it with the wrong board) and it worked. The set turned off after only 2 minutes, but then I noticed the fan was not connected. Upon hooking up the fan, everything now works. Glad I asked on here, I was pretty sure the panel had a short, based on the picture and my belief that the buffer boards were good.
                So you had two buffers with the exact same failure? Once in a lifetime fault that is...
                • keats11
                  • Nov 2012
                  • 88
                  No no. let me explain this in chronological order. I got this TV from someone, knowing it had some kind of fault. WHen I bought it home and turned it on, it looked like the picture I posted. Then I remembered, I possibly had buffers boards that looked like these from another TV I fixed a while ago, so I put that in and it looked the same as the picture I posted also. That is when I posted on here to see if this could be a panel issue. Little did I know that the people whom from I bought, might have tried to fix it, with the same buffer boards that I had spares of. These buffer boards strangely enough produces the picture I posted. I ordered the correct boards from ebay and it came back up full screen. Really strange!
                    So... What I'm trying to understand is two separate sets of buffers gave the SAME picture fault down to that bar with that pixel line? You should buy a lottery ticket. Well maybe just bet on a horse. 1/768 chance of that happening.
                    • Zelek11
                      Panasonic Plasma screen interference on left half of screen
                      by Zelek11
                      My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                      This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                      10-14-2022, 04:54 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • renech
                      panasonic TH-42PC77U plasma television half screen problem
                      by renech
                      hello,
                      I hope someone on this forum can assist me.
                      I have a panasonic TH-42PC77U plasma television.
                      the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                      i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                      I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                      I have read some posts that suggest the problem is related to the boards on the left...
                      12-12-2022, 06:53 PM
                    • hasel17
                      CH341a can erase and read but can't write and blank check
                      by hasel17
                      So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                      Code:
                      Checking for blank...
                      (Press
                      10-26-2023, 06:20 AM
                    • Formaster
                      Sony KD75XE9005 Bottom half double image
                      by Formaster
                      Hi guys,
                      I'm tyred from these sympthom, if anyone helps me really big thx.
                      When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
                      08-10-2021, 06:57 AM
