SharpLC 52D64U Signal kills backlight
  • G Nicholls
    • 19
    I am servicing a Sharp LC 52D64U. It is similar to the 42, 46, 52, & 65" models in the D64 series. The board views and service manuals are in existing posts.
    This unit had a typical backlight failure: a pair of shorted MOSFETs on the slave inverter board. {J655 and K3706} I ordered up IRF539N and IRF9530 from Jameco that are 100V 17A rated N & P channel replacements. The repair seems fine, BUT ONLY WHEN THE UNIT IS IN "MENU" MODE OR WITHOUT A SIGNAL INPUT IN THE OTHER MODES.
    So, the unit is fine when processing it's own generated "video" {menu selections} but not with the tuner or VGA inputs (the only modes I verified) are selected.
    Has anyone experianced this? I suspect:
    1) The replacement MOSFETs have too different a technical spec issue to work reliably under all conditions. {Unlikely as the unit will disply happily for hours with only the self-generated menu screens displayed.}
    2) The TCON is dropping the backlight on command {Seems unlikely as the video drive signals in menu mode are fine enough to keep the set happy.)
    3) the problem is a "fault" that is still stored in the memory and will kill the backlight and cause the frontpanel "green light blink" upon a normal input like the tuner or VGA input.
    4) There is a fault with the IC8001 AV Decode & Main CPU (or similar) due to a voltage regulator unable to supply the circuit when in operation (under load) of signal processing.
    This set is a frustration as the original defect, no power-up, was traced to a shorted inverter pair of MOSFETs and likely repaired.
    Just my favorite emoticon!
    Any other folks have this issue and find a component level solution? This unit is a bit marginal for a $100 replacement video board that might not be the issue and the inverter board repair.
    I do enjoy the challenge or these repairs and the helpvided by the forum users. Beer for all of you, and your horses!
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: SharpLC 52D64U Signal kills backlight
    I would think it might be a fault in the main board not processing the video signal correctly and seeing a fault causing the tv to shut down. Just guessing though. Are you getting correct voltages at all boards when the problem occurs.
    • G Nicholls
      • 19
      Thanx for the reply. The power supply voltages seem fine when the set has no input from the tuner or VGA inputs (did not have equipment to feed HDMI inputs in the field). Did not check them when it shuts down the backlight. Good thought though. If the 60volt feed shuts down, that would explain alot.
      I doubt this is the case. I think the control signal to the inverters (like from the TCON as is typical in many sets) is turning them off.
      I downloaded the service info online. I will check to see if there is any fault info stored in the EEPROM. It sure had a hard short in the inverters, and perhaps a fault bit is being stored. I have had little success repairing Sharp units in the past, so my experience base with these units is very limited.
      Any Sharp techs out there?
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • alltvrepairs
        Jvc Lt-65VU3000 reduce backlight from service menu
        by alltvrepairs
        I have just replaced led set of this vestel tv due to age.
        I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
        Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
        Thanks again....
        09-20-2025, 05:03 AM
      • khj
        a2338 no backlight (i2c_bklt_sda, i2c_bklt_scl no signal)
        by khj
        Hello.
        I have a problem about backlight.
        I changed almost backlight parts, but I can't get over 40v from them.
        I think display connect signal is missing. (I2C_BKLT_SDA, I2C_BKLT_SCL is just pull-up voltage (5.18V) when I connected edp )
        so backlight circuit doesn't step-up voltage.
        normal logic board has I2C signal. but bad one is missing.
        what should I do?...
        01-24-2024, 02:20 AM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
