Advice needed! Samsung tv
  • Hamie
    • Apr 2014
    • 1383
    Picked up a 42" Samsung with no power.
    After replacing the faulty caps and a couple of resistors the tv came back to life.
    However, it keeps turning off and on.
    The longer it's on the faster and more frequent this happens.
    So I assumed it was over heating. So started freeze spraying the caps to find out what one was causing this.
    Eventually found the spot that was causing this but it turned out to be a resistor.
    As long as the resistor is cold the tv stays on.
    Assuming the resistor was bad I ordered a new one (without checking if it was actually bad) swapped it over and it still clicks on and off!
    Now the real problem, I lent my multimeter to my dad assuming that i had located the problem and didn't need it.
    I have loads of parts lying around that can be used to fix this problem but looking for advice on what one to take out first!
    RS817 is the resistor that need frozen for the tv to work.
    The board is BN96-03743A
    Any advice will be much appreciated.
    Re: Advice needed! Samsung tv
    I'd check for cold joints in that area, should that fail consider replacing CS811 & nearby capacitors.
    • Hamie
      • Apr 2014
      • 1383
      Ok so update on this telly.
      Status: still doing the same!
      Don't think it's bad joints, gave the psb a good whack when it was on and it didn't turn off.
      And reflowed everything around the resistor that needs chilled.
      Tom you were right about that cap, it was out but still didn't fix it!
      Checked all other caps around and all were good.
      I have my multimeter back now, so any suggestions would be greatly appreciated.
      Anyone got the schematics for this board.
      Cheers
        • 31092
        i'd be more inclined to suspect the nearby diode or chip geting cooled at the same time.
        that or the resistor is getting hot because it's connected to something that is pulling too much power.
        • Hamie
          • Apr 2014
          • 1383
          I thought the same, so I angled the spray so only the resistor was getting chilled, it's definitely just the resistor that needs cooled to stay on.
          Replaced the diode next to the resistor as was slightly low, .46 if memory severs me right, but still didn't solve the problem.
          The closet ic is viper22a can't find much information about it.
          If all else fails I'll have to go through everything one by one, but hoping someone might have had similar issue.
            • 31092
            VIPer switching regulator.
            made by ST
            http://www.st.com/web/catalog/sense_...S1835/PF215018
            • Hamie
              • Apr 2014
              • 1383
              So it's the viper22a that's shutting the tv down.
              But is it faulty or just doing it's job? How do I test this part?
              If not do I conclude that it's should be a part on the left hand side of the board that maybe bad?
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                pic from bottom side of board around that area? Any component there? Hairline crack in one of the traces?
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                • Hamie
                  • Apr 2014
                  • 1383
                  I'm happy to say the telly is now fixed.
                  it's been on for 2 hours so fingers crossed.
                  Incase anyone else finds a similar problem. Here's what i replaced.
                  Electrolytic Caps
                  Cs808
                  Cs806
                  Cs811
                  Cs404
                  Cm421
                  Cm422
                  Ceramic caps
                  Cs810
                  Cs813
                  Diode:
                  Ds805
                  Resistors:
                  Rs817
                  Rs822
                  Ic chip.
                  Ics801s
                  • tibimakai
                    • Jan 2012
                    • 3680
                    It would help even better if we knew the model number of this TV.
                    It's a good idea. to put it in the tile.
                    • Hamie
                      • Apr 2014
                      • 1383
                      PS42QHD
                      How to I edit the title?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Nice good job on the fix!
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
